No spark!
Old Aug 26, 2011 | 05:31 PM
86toypu's Avatar
No spark!
Hi guys, i just bought a 86 toyota p/u, ran good for a week got home from work go back out to the truck to leave and it wont start. I discovered its not getting spark so i replaced coil,cap,rotor,wires and plugs. still no spark, the truck turns over no problem and is getting fuel. any advice would be helpful. thank you
Old Aug 26, 2011 | 05:44 PM
myyota's Avatar
I had the same problem on my 86 4Runner. There is an ignition fuse in a fuse box behind the driver side kick panel, pull the fuse out and check it, on my 4Runner it was corroded and lost contact. I cleaned the contacts in the fuse box as best as i could with a small screw driver and replaced the fuse. Its been working just fine ever sense.
Old Aug 26, 2011 | 05:55 PM
86toypu's Avatar
thanks for the reply, i checked that fuse it looked good but i went ahead and replaced it anyways, didnt work though.
zytra
Jan 24, 2019 03:16 PM
Kamaloha
Oct 16, 2015 05:13 PM
shredder4286
Oct 1, 2015 01:09 PM
voiddweller
Sep 28, 2015 11:21 PM
Rcbc92
Sep 26, 2015 03:00 PM
