Dur, what's this wire do?
Old Aug 23, 2011 | 05:57 PM
Tower0fPower's Avatar
Tried installing a subwoofer and replacing all the factory speakers in the runner today. Hit some hiccups...
Problem #1: Basically there's no power to the rear speakers, wtf mate? Rear speakers as in the ones in the cargo bay that are enclosed in a black plastic vented box and amplified from within the box.
Problem #2: Possibly related to Problem #1.. This wire (see attached photographic evidence!) has no home! There is no receptor for this connector. No yin to this yang. I are wondering if it is a remote wire for the amplifiers in the rear speaker boxes?
Old Aug 23, 2011 | 06:21 PM
Oh yea! 1995 4Runner SR5 3.0 4x4 yada yada
Old Aug 23, 2011 | 06:29 PM
irab88's Avatar
white with a green stripe, seems to me, to be a ground. try jumping it to ground and see what happens. if you see a lot of sparks, that's not a ground
Old Aug 23, 2011 | 06:47 PM
mwc0404's Avatar
may be the either the positive or negative for the rear speaker, probably the negative.
Old Aug 23, 2011 | 07:06 PM
vital22re's Avatar
totally a bro
bypass the factory amp.
Old Aug 23, 2011 | 07:07 PM
I'm thinking tomorrow I'll find a nice bare spot of metal and see if I can get some sparks to fly and then have fun tracking down that illusive blown fuse. Thanks for suggestion!
I don't believe it's a speaker wire as those are all accounted for and already spliced into my wiring harness. But it's possible, I'll re-recheck my wiring tomorrow morning.
Old Aug 23, 2011 | 07:15 PM
yotarover's Avatar
pwr supply back up
Old Aug 23, 2011 | 07:16 PM
yotarover's Avatar
my 86 came with a factory working radio ( tape player) took it out. diagram said that lil clip was for the power supply backup
dont think it's changed to much, was the same in my 89 as well
Old Aug 23, 2011 | 07:29 PM
What exactly is a power supply backup? Is that just a secondary 12V wire that is hot when the ignition is on then?
Old Aug 23, 2011 | 07:34 PM
vital22re's Avatar
totally a bro
86 and 95 are two waaaaaaaaaaay different years.
Old Aug 23, 2011 | 07:37 PM
Do you know the output on the factory amps? If they exceed my headunit I might as well integrate them, but if they don't then I can see value in bypassing them.
Old Aug 23, 2011 | 07:54 PM
vital22re's Avatar
totally a bro
they do not.. remember.. they were "banging" in 1995... its 2011 now... any stereo shop will bypass the factory amp as its not worth a darn.. Your new head unit over powers it.
Old Aug 23, 2011 | 08:22 PM
That's probably true, and I've already removed the front factory amplifier so it would be unbalanced to have the rears amplified from the factory. Kind of an empty victory now that I'll be bypassing them but I just figured out how to integrate the rear speakers...
After some keen searching I discovered that the rear speaker amplifiers are triggered by the power antenna which is only powered when the radio is on, not when I am trying to listen to my iPod... The workaround is to connect the remote amplifier wire (essentially an ignition wire) from the headunit to the power antenna wire (the blue wire in the harness.)
As far as that other green/white wire goes I'm still stumped unless it truly is the power supply backup. In which case I'm still not sure what its purpose is
Old Aug 23, 2011 | 08:47 PM
vital22re's Avatar
totally a bro
grab a multimeter and test it.
Old Aug 24, 2011 | 12:44 AM
TNRabbit's Avatar
pwr supply back up
I'm pretty sure that's it--unless it's plugs into the cigarette lighter~
Provides power constantly so you don't lose your radio settings.
80Truck
Oct 12, 2025 07:25 PM
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
ToyoToler
Aug 8, 2015 08:43 AM
Daneums
Jul 28, 2015 11:57 AM
TDonkey
Jul 26, 2015 10:14 AM
