1988 22re timing issues
Old Aug 23, 2011 | 05:21 AM
justin graham's Avatar
I've searched the archives and couldn't quite find an answer to this problem. I've got an '88 pickup w/ 22re that I recently replaced the head gasket and re-worked the head on. The truck always seemed to be a bit anemic when it came to power, even after re-building the head.
The problem I ran into when trying to time it was that I could not get it to idle down like it should after crossing the 2 connectors in the diagnostic terminal. Because of this, I was unable to use a timing lite and just put it in time by ear. I thought I read somewhere on the forum here about the TPS being out of adjustment and causing a similar problem when timing. I've got to run by the autoparts store sometime this week to replace my old feeler gauge so I can check out the TPS, but is there anything else I should be thinking about that could be the culprit?
Thanks,
justin
Old Aug 23, 2011 | 05:42 AM
xxxtreme22r's Avatar
when putting the jumper in was the check engine light coming on and flashing? if not that's your problem. It can be a little tricky to get the jumper in and working.
6th Gear
19
Dec 10, 2019 07:31 AM
noahstancik
Jul 10, 2015 11:18 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
saphirekosmos
Jun 22, 2015 10:26 AM
bobbybouche
Jun 18, 2015 10:22 AM
