ignition coil interchangeability
Old Aug 21, 2011 | 05:08 PM
brysawn's Avatar
I've got a 86 pickup that I believe to have a bad ignition igniter, but when I went to remove the one from my 94 pickup, I noticed they were different. Can they be used between each other, with or without the coil?
Old Aug 21, 2011 | 05:17 PM
bone collector's Avatar
what motors are in the 2 trucks?
Old Aug 21, 2011 | 05:28 PM
myyota's Avatar
The ignitor and the coil are two seperate parts, so you need to figure out which one is bad. The coil is a cheap part to buy, but the ignitor can be very expensive.
Old Aug 21, 2011 | 05:29 PM
brysawn's Avatar
Oh man, I can't believe I forgot to put that. They are both 22re's
Old Aug 21, 2011 | 05:30 PM
brysawn's Avatar
The igniter is bad. But I noticed that the one on my 94 has a different number on it then the one on my 86. I'm assuming they can't be changed
Old Aug 21, 2011 | 05:32 PM
myyota's Avatar
The ignitors are probably the same, but the plugs will be diferent
Old Aug 21, 2011 | 05:36 PM
myyota's Avatar
I have read on here, were people have unsoldered the plugs from a diferent ignitor and soldered the plugs from there bad ignitor onto the new one and it worked. All you can do is try it, it might work.
Old Aug 21, 2011 | 08:38 PM
brysawn's Avatar
Yeah I can see that. But for that much work I might as well just buy a new one
MadMax48
Mar 3, 2020 10:33 AM
mojo4x420
Sep 16, 2015 08:07 AM
JHalcyonM
Sep 14, 2015 01:10 AM
icentropy
Sep 10, 2015 05:03 AM
