Intermittent starting problem.....Help!!
Old Aug 11, 2011 | 09:48 AM
texasrecurve's Avatar
I have an intermittent starting problem with my 89 4wd pickup, 22RE. It is a manual. For a while now, you have to have the clutch down in just the right spot or it will not start. Lately, it seems no matter how you press in the clutch it may not start and you have to use the over-ride button on the dash to allow you to start the truck without engaging the clutch. Now however, it refuses to start about 1/3 of the time no matter what you do. The battery has plenty of power, that's not the problem. Its left me stranded twice in the last 3 days. Help!
Old Aug 11, 2011 | 09:58 AM
4Crawler's Avatar
See below:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
See if you can rig up some wires to let you keep a volt meter in the cab, then watch the voltage while starting when it works fine and when it does not and if there is a difference, then track down the cause.
Might be your clutch cancel switch or relay:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
colinmil
Jul 6, 2015 04:03 PM
