94 4Runner cruise control
Old Apr 21, 2015 | 12:22 PM
cpfdrew01's Avatar
Hey guys,
On my 94 with a v6, 5 speed, the cruise won't set. The light on the dash comes on, doesn't flash or anything, but when I hit set it doesn't do anything. All the research I've done says there should be a vacuum actuator up by the brake booster, but there's not. All I see up by the throttle body are a dashpot on the front and another vacuum diaphragm of some sort on the back. Neither have any electrical plugs or anything... Is there somewhere else I should be looking for the cruise actuator? I'm guessing that's where the problem lies..
Old Apr 21, 2015 | 12:29 PM
scope103's Avatar
Are you sure you have cruise control?
Here's the page of the manual: http://personal.utulsa.edu/~nathan-b...10cruiseco.pdf
At some point (I don't know by year), Toyota used an electrical actuator. I have vacuum.
Do you have two throttle cables to the throttle body? One is for the accelerator pedal, the other for the cruise actuator. Just trace it.
(If you had an automatic transmission, there would be a third throttle cable.)
Old Apr 21, 2015 | 05:40 PM
RJR's Avatar
RJR
My '94 has electric cruise control. The actuator is a servo motor that sits on the passenger side fender with a throttle cable running to the throttle body, as scope says.
Check out the diags in the FSM pages scope has linked. That'll be the best place to start.
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
coryc85
Sep 9, 2015 06:24 AM
mengquis
Jul 13, 2015 10:39 AM
cyclist231
Jul 7, 2015 12:56 PM
