How to keep stock battery gauge, GM alternator
Old Apr 27, 2015 | 01:06 PM
MikeNasty's Avatar
1985 4Runner 22re 5speed
I'm a long time lurker on here...I'm interested in swapping in a GM alternator. I have already bought the bracket, alternator, and pigtail to splice. My question is, how do you keep the stock battery gauge working?
I read a long time ago about the use of a 50 ohm resistor, but can't find it anymore. I don't care wether to "1-wire" or "3-wire" it, as long as it charges and the gauge works.
I've searched and searched, but haven't read anything definitive on how to keep the gauge working. Thanks!
Old Apr 27, 2015 | 02:36 PM
scope103's Avatar
Does a '85 4runner have a "battery gauge"? I (1994 pickup) have an voltmeter and an "alt" lamp. Both are useful/necessary to monitor the electrical system, but neither is a "battery gauge."
Do you know what kind of GM alternator you have? This article http://www.pirate4x4.com/tech/billav...ng/Part2/#lamp lists at least four different types. And describes how to hook up each one.
The "resistor" that you may be referring to allows you to use an "alt" light with an obsolete "1-wire" alternator, and keep the alternator working (to the extent it works at all) if the bulb burns out.
But the cited article may help straighten it all out for you.
Old Apr 27, 2015 | 03:20 PM
MikeNasty's Avatar
Sorry, I meant voltage meter on the sr5 gauge cluster.
The alternator I bought is a 150 amp Powermaster part# 47294. http://m.summitracing.com/parts/pwm-47294
Old Apr 27, 2015 | 04:27 PM
scope103's Avatar
Didn't you already replace your alternator a few months ago?
Old Apr 27, 2015 | 05:10 PM
muddpigg's Avatar
Sorry, I used the cs130 don't know how to wire in the 12si.
Old Apr 28, 2015 | 12:36 AM
wyoming9's Avatar
Red face
From the EWD from your vehicle find the wire that feeds the voltmeter then that can be connected any place you want I like to hook direct to the battery .
I guess it might be called a battery gauge when the alternator is not spinning .
Old Apr 28, 2015 | 06:56 AM
scope103's Avatar
Originally Posted by wyoming9
From the EWD from your vehicle find the wire that feeds the voltmeter ...
The voltmeter is built-in to the combination meter, and measures the voltage on the "bus" in the meter itself. Which is usually what you want; if you have a problem with the wiring that causes a big voltage drop, it doesn't do you a lot of good to have a meter telling you there is "no problem." More importantly, if MikeNasty is just replacing his alternator, he doesn't have to do anything to the voltmeter to get it to work the "factory" way once he gets the alternator hooked up.
MikeNasty's problem is trying to hook up an alternator that doesn't have the connections needed by his truck. The article I cited does a pretty good job (I think) of going through his options.
Old Apr 28, 2015 | 08:42 AM
osv's Avatar
osv
the first step in charging system troubleshooting 101 is to put a voltmeter across the battery terminals, and see if there is higher voltage present, than what the voltage of the battery is with the engine not running... and that's exactly what wyoming9 was suggesting.
i guess that we'd have to look at the schematics and see where that "bus" hooks up... but generally when there is a big voltage drop, there is going to be a lot of heat being generated, so things will be burning long before you see the meter on the dash, or in a properly designed system, fuses will have already blown... so i don't see much advantage to hooking up the factory voltmeter anywhere other than directly across the battery.
o.p., here is a recent thread with the 12si hookup: https://www.yotatech.com/forums/f116...stions-276603/
i have that same 47294 from powermaster, it's been good for me so far, but i still question the validity of my install... i guess that it's human nature to think that we have to do a bunch of rewiring to get this to work.
in my case, i hooked up the fat wire that came with the alternator, directly to the battery... 1)i sleeved it, but didn't fuse it, and i probably should have, 2)i don't yet have any external winch or welder hooked up, so why do i think that i need the additional current-carrying capacity of that fat wire, back to the battery?
Old Apr 28, 2015 | 09:42 AM
scope103's Avatar
osv - The article you cite (https://web.archive.org/web/20120905...%20Project.pdf) describes fabbing and welding mounting brackets at the top and bottom of the new alternator. Did you have to do that?
Originally Posted by osv
...in my case, i hooked up the fat wire that came with the alternator, directly to the battery... 1)i sleeved it, but didn't fuse it, and i probably should have, 2)i don't yet have any external winch or welder hooked up, so why do i think that i need the additional current-carrying capacity of that fat wire, back to the battery?
A dead battery is almost a dead short; your new 175 amp alternator would end up trying to drive a lot more than 175 amps unless the fuse blew. An accidental slip during battery jumping would make a real dead short. The purpose of the fuse is to protect the wire from the unexpected; it doesn't matter whether you have a winch or welder (those would be design loads, which should never blow a fuse).
Old Apr 28, 2015 | 12:57 PM
osv's Avatar
osv
that makes sense, a winch could easily pull hundreds of amps, it would be difficult to fuse... my bronco goweld is rated at 24v/200 amps.
i gotta get a fuse going with that direct line from the alternator to the battery... it looks like anl type fuses are the only form factor that handles 150+ amps.
i have the trail gear bracket, it's bolt-in, but i modded it heavily... had to cut off nearly half of the fork length, because it was fouling the hydro-assist, replaced the long main bolt with a metric bolt, because it fit the hole much better, and welded the factory toyota alternator mount brace onto the trail gear brace(belt tension fork piece), which added an xtra bolt to mount it to the block... much more stable.
Old Apr 28, 2015 | 01:57 PM
wyoming9's Avatar
Red face
The only reason I want a voltmeter is to know the alternator is working like it should.
The voltage at the battery.
If there is a large enough draw it will show up
Old Apr 28, 2015 | 02:14 PM
muddpigg's Avatar
Scope thanks for your first post that link has loads of info and I think I'll eventually change my wiring set up. With additions of electrical accessories my battery post look like the terminal buss. Hadn't seen that the cs130 was more or less a disposable alternator. Really don't know why anyone would run a one wide set up in our trucks, but if anyone has it is your rig and a free country so rock on.
Thanks again, Scott
Old Apr 28, 2015 | 02:27 PM
scope103's Avatar
Originally Posted by muddpigg
... why anyone would run a one wide set up ...
One wire? If so, I agree.
Toyota put all in I, S, L and B for a reason, so I'm not sure why anyone would try to get by with a 1, 2, B alternator. Each to his own.
Old Apr 29, 2015 | 02:09 AM
MikeNasty's Avatar
Exactly what I needed. Thanks!
80Truck
Oct 12, 2025 07:25 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
redneck17
Oct 29, 2015 09:09 PM
Poncho0206
Jul 10, 2015 06:21 PM
colinmil
Jul 6, 2015 04:03 PM
