22re throttle surge/pulsating
Old Apr 24, 2015 | 11:33 AM
Shagool22's Avatar
This just started today. Last night I replaced vacuum hoses 1 by 1 so they are all correct. I also replaced pcv valve and grommet. I didn't notice this last night. When I started it up today it started doing this. Idles perfectly fine. One does this when giving it throttle
UPDATE: only does this after warm. Does not do it when cold
Video-
Old Apr 24, 2015 | 03:02 PM
Peart130's Avatar
Check the AFM? I had similar idle issues after the spring broke on my unit, it kept the door shut keeping air from entering the ECU.
Old Apr 24, 2015 | 04:00 PM
Shagool22's Avatar
Yes I checked afm resistance, all good..
Could this be bad TPS?
Old Apr 24, 2015 | 09:08 PM
Shagool22's Avatar
Really need some input here!! Stuck in the water
Old Apr 24, 2015 | 11:43 PM
grumpin's Avatar
Did you try the old PCV valve? I would check the hoses again, since it ran good before.
Old Apr 25, 2015 | 09:59 AM
Shagool22's Avatar
Yes I tried old pcv and put all the old hoses back in yesterday. Problem still there. I think the problem is elsewhere just a coincidence it seems to have started after replacing hoses..
Old Apr 25, 2015 | 12:24 PM
grumpin's Avatar
Yeah, that stinks. I always think it's something I did. Might check the coil, see what the ohms are. Or fuel pump and filter. Heck, I might even pull the negative battery cable off for awhile.
Old Apr 25, 2015 | 02:33 PM
Shagool22's Avatar
Thanks will check those. And negative cable has been off all day. I've got tonight and all day tomorrow to figure it out...
I have a hard time following the quote "if it ain't broke don't fix it." Lol seems like every time I try to do a little preventative maintenance a problem occurs!!
Old Apr 25, 2015 | 03:11 PM
Terrys87's Avatar
Try burping the system of air in the coolant system. That will cause surging.
Old Apr 25, 2015 | 06:47 PM
Shagool22's Avatar
Problem solved, I was wrong. Somehow I did manage to cross up a vacuum line at throttle body. All new hoses in and running like a champ again.
Old Apr 25, 2015 | 08:53 PM
grumpin's Avatar
Old May 4, 2015 | 11:31 PM
stanz's Avatar
Smoke test the intake for vacuum leaks. I had some bumps in the idle and swore that I didn't have any vacuum leaks. Smoke test proved otherwise and the idle smoothed out. These motors act up on the slightest vacuum leak.
Old May 5, 2015 | 09:29 AM
Shagool22's Avatar
Stanz my idle is great! No bumps or anything. I solved this issue a while back it ended up being that after I changed vacuum lines I crossed two up..
Now I'm dealing with a sticking throttle!! Can't figure it out
montanatruck
Feb 26, 2017 07:07 AM
Dennisx2
Aug 10, 2015 06:48 AM
Sidherish
Aug 3, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
