87 4runner wont start
Old Apr 11, 2015 | 12:37 PM
symlink's Avatar
I jumpered the diagnostic port and forgot i had it in cranked it up an drove maybe a 1/4 mile before i pulled over to take it out. Pullee it out hopped back in and tried to start it no dice. Checked fuses all are good from what i can tell. When trying to crank it clicks tried smacking the starter good too and that didnt work so did a push start to get it back home. Any ideas maybe something im missing here? My next move is to try and test the starter. Is there a procedure for testing the starter relay? Also pulled that battery and had it tested.
Old Apr 11, 2015 | 01:17 PM
Rusted Rooster's Avatar
check relay, drivers side kick borad, right below fuse box
Old Apr 11, 2015 | 11:23 PM
wyoming9's Avatar
Red face
Just what did you have jumped in the check connector??
I think you might have a poor ground problem .
When you pulled over was the truck sitting level??
I have seen ground problems caused by flexing of the vehicle.
Time to break out the meter
Old Apr 12, 2015 | 06:24 AM
symlink's Avatar
I had the T and e1 jumpered battery is at full charge im going to check all the grounds this morning and yeah it was sitting pretty level
Old Apr 12, 2015 | 06:59 AM
symlink's Avatar
Got it fixed the cable to the starter actually had become brittle and fell out of the connector after i had moved the cables like 10 times. Always helps to take time away and to have other peoples input it helps. Thanks guy! Also if your sure your connections are good check them again lol
JF9243176
Oct 8, 2017 04:21 AM
vasinvictor
Jan 20, 2016 12:39 PM
torgeir
Jun 25, 2015 05:26 AM
JF9243176
Jun 24, 2015 04:53 AM
JaredL
Jun 16, 2015 04:47 PM
