93 Toyota pickup auto trans problem!
Old Apr 13, 2015 | 05:12 PM
bebo_vi21's Avatar
I'm having trouble with my auto transmission after a drain, filter and gasket replacement and a refill. If got 7 quarts and a Lucas trans oil and still not showing up on dipstick. Goes in drive but doesn't take reverse. Any help is greatly appreciated. Do I need more fluid? What would be my next step to try out.
Old Apr 13, 2015 | 05:38 PM
scope103's Avatar
If you had done any sort of search before posting, you surely would have come across the suggestion to check for codes.
Well, here you go: http://personal.utulsa.edu/~nathan-b...31diagnosi.pdf
This page is for an A340H, but it applies to all A340s. You didn't tell us which transmission you have (hint: it's listed on the door pillar).
Old Apr 14, 2015 | 02:42 AM
bebo_vi21's Avatar
A340h and I have no codes.
Old Apr 14, 2015 | 02:45 AM
bebo_vi21's Avatar
Sorry ill check for codes this afternoon where is that plug located?
Old Apr 14, 2015 | 06:18 AM
scope103's Avatar
Next to R/B 2, under the hood.
http://personal.utulsa.edu/~nathan-b.../2powersou.pdf
Old Apr 14, 2015 | 04:22 PM
bebo_vi21's Avatar
i jus checked for codes as the file stated to do and it blinked 2 per second meaning everything is normal not getting any codes. i have 9 quarts in it and now im seeing its marking to the cold mark on the dipstick after vehicle is at normal operating temperature. could it be that the reverse gear is burnt out?
Crazychris1871
Jun 27, 2016 10:38 AM
Aleeex_u
Jun 5, 2016 06:52 PM
vasinvictor
Jan 20, 2016 12:39 PM
BLRobertson
3.4 Swaps
Jul 10, 2015 04:27 AM
GorgeRunner
Jun 27, 2015 07:01 AM
