Front Differential Assembly Replace
Old Jan 30, 2010 | 04:11 PM
Tanker5503's Avatar
I am planing on replacing it tomorrow and and was looking at what i need to take off today. The bolts that Connect the CV shafts plates have to come off and 3 mounting bolts for the diff. Anything else i should know or tips to take it off? Thanks
Old Jan 30, 2010 | 04:24 PM
kiyobrown's Avatar
Type in "linky to zuk" trust me it will lead you right to it. I am on my iPhone, hard for me to get it for you.
You have it right. Held in by 3 bolts, and 6 bolts for each cv joint.
The link will have the list of tools to make it quick. He said take off the crossmember. I didn't and it still went smoothly.
One tip, don't sit under it as you try to lower it down.
Almost forgot. Don't know if you have an add front diff or not. If you do, I think it's one electrical plug and 2 vacuum lines.
Old Jan 30, 2010 | 04:32 PM
Stuwy123's Avatar
The bolts on the CV shafts are splined.
You'll need a long drift punch and a hammer. I've used the stock jack extension before, works good.
Punch all the bolts out of the CV shafts before you undo the three bolts to the frame.
Make sure you have that thing supported and secured or else it'll come crashing down.
Old Jan 30, 2010 | 04:34 PM
kiyobrown's Avatar
http://www.gearinstalls.com/ifs.htm
found it.
Old Jan 31, 2010 | 10:47 AM
OutlawMike's Avatar
And, if you have the time and inclination, grind the knurls off of the CV shaft bolts before re-installing. That way you can do a trail fix a lot easier, they just come out like regular bolts.
I took the time and the time and filed mine off on a lathe.
Old Jan 31, 2010 | 11:02 AM
Tofer's Avatar
Sponsor
I sell an ifs diff studless kit. That converts the studs to standard bolts. I am outta stock right now but should get a shipment in soon. It makes swapping out diffs or CVs much easier.
Old Jan 31, 2010 | 11:48 AM
Matt16's Avatar
Or you can just grind off the splines off the stud to make a bolt... takes maybe 30 seconds per stud.
bigjstang
Jun 2, 2025 03:56 PM
lledwod
Aug 30, 2016 01:03 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
