1990 toyota 4Runner power problems
Old Jan 31, 2010 | 09:47 AM
Seth Black's Avatar
Yesterday I drove out to pick something up, car has been running perfectly fine. I saw a light come on my dash saying "rear anti lock" it flickered on for a few seconds. When i got to my destination stopped the car and came back about 5 minutes later the car was completely dead. No battery no electrical units anywhere were working. checked the fuses they were good, jump started battery didn't work. took battery out (it was old) took it to autozone they tested it, came back bad.
So we bought a new battery installed it and thought that would fix it but nothing happened it was as it had always been. the new battery is tested good. I'm told that the problem now is probably a fuseable link in my starter cable to the battery. I'll probably research that more would appreciate it if anyones had a similar problem before and could help me out, much appreciated!
Old Jan 31, 2010 | 10:23 AM
r8cfreak's Avatar
someone told me it was supposed to be on but now im guessing whoever told me must of missinformed me. So id like to know what the real deal is and how i can fix it
Old Jan 31, 2010 | 10:44 AM
calipatient's Avatar
take a screwdriver w a plastic and handle and touch the bolt where the battery cable connects the starter... if you get an arc? the starter has power.
...one time i had the wire from the ignition to the starter tug on the connection and it broke the soldering inside the starter (where the plunger is)
Old Jan 31, 2010 | 10:46 AM
but no radio/lights either?
Old Jan 31, 2010 | 11:24 AM
Seth Black's Avatar
no nothing is working. i bought a new cable for the starter to battery working on replacing that now.
Old Jan 31, 2010 | 11:25 AM
Seth Black's Avatar
well actually its from the battery to the fusebox in my 1990 4runner.
Old Jan 31, 2010 | 11:46 AM
that sounds more like the culprit. mine was old and cracked... so i had to do the same a few months ago.
Old Jan 31, 2010 | 11:48 AM
myyota's Avatar
Check the power wire from the battery to the fuse box next to the battery, if its bad or broken you won`t get any power to anything, i had this same problem happen to me on an 84 4Runner. I had to replace that wire and everything worked fine after that.
vasinvictor
Jan 20, 2016 12:39 PM
GorgeRunner
Jun 27, 2015 07:01 AM
JaredL
Jun 16, 2015 04:47 PM
