Frozen Key Barrel
Old Feb 2, 2010 | 05:23 PM
JSimmons's Avatar
Frozen Key Barrel
Hi all,
Anyone have a good cure for a frozen key barrel? My tailgate key barrel won't turn to the left or right. I've soaked it in WD-40 so we'll see how it works in the morning. Is it pretty easy to swap out key barrels?
Old Feb 2, 2010 | 05:33 PM
Junkers88's Avatar
I was going to advise the WD-40 idea but you already did that. I did that to mine and it works every time now.
Old Feb 2, 2010 | 05:45 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Water Displacement on the 40th try needs to be part of winter PM.
I always hit my door gaskets, up under the handles, striker and barrel with it... Door opens easy after that.
It shouldn't freeze after that until the WD40 wears off b/c you need moisture to freeze something and most of water is moisture
You might have bigger issues if you've doused it and it still won't turn... Or you didn't give it long enough.
Old Feb 2, 2010 | 06:08 PM
JSimmons's Avatar
Well, this was one of the gremlins that I knew about when I bought the rig. When I test drove it about a week or so ago before the snow came in, the barrel was "frozen" in 45 degree weather. I'll soak it again and see what happens. I'm thinking there might be some sort of mechanical blockage or something.
Old Feb 2, 2010 | 06:16 PM
corax's Avatar
you could also try spray penetrating oil - it'll work a bit better than WD40 if the tumblers in the lock cylinder are sticky
Old Feb 3, 2010 | 05:13 PM
JSimmons's Avatar
Yep, still not working. Think I'll take it to a locksmith tomorrow.
Old Feb 4, 2010 | 06:50 AM
BeenYota's Avatar
Minnesota born - Frozen lock solution
Wish I could have helped earlier. I use the little Qualco pressurized Lock De-Icer cans sold everywhere around here. Insert the nozzle into the keyhole and press against the lock. Drives the water out of the lock and coats it with a protective lubricant. I wash my rust-free truck frequently to remove road salt, and even when temps are below zero degrees Fahrenheit all it takes is 1 shot and the locks are free and smooth. Weather stripping, hinges and windows are another story but I have a solution for those too. I keep a couple of these cans in a dry-erase marker holster under my truck.
Never use WD-40 or graphite for locks kid. You'll only gum up the lock.
Google it; you can pick it up for a buck. If nothing else when the lock smith extracts the barrel have him clean with de-greaser to remove the WD-40 and other contaminants.
Old Feb 4, 2010 | 07:12 AM
874runnersr5's Avatar
That white lithium lube in a can worked wonders for mine.
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
JamesDINAN
Sep 22, 2015 05:37 AM
AustinTaco
Sep 18, 2015 08:58 PM
