SAS Questions
Old Jan 29, 2010 | 06:04 PM
DanStew's Avatar
SAS Questions
Here is a picture of my front springs. The truck is an 86 and it was SAS'd by the PO. THe shackle in the front is 3.5 inches bolt to bolt, and from reading, this is a stock shackle size. What is the size shackle that i should have on here? or shall I say, are you not supposed to use stock shackels for a SAS?
And this is a longshot.
I have no idea of the manufacture of my springs. There are no identifying markers, except on the rear springs it says ToyotaRear37 in stencil. The front has the old backings of decals but no text.
My issue is i want to drop the lift down and I jsut want to see what I have to begin with. The rear shackels are 6.5 inches bolt to bolt, and there is even a 2 inch block under the spring. I know how i am gonig to lower the rear, but if i go for a longer shackle in the front I am going to gain lift. GRRRR.
Thanks
Old Jan 29, 2010 | 06:07 PM
waskillywabbit's Avatar
5 to 6 depending on springs and setup.
Old Jan 29, 2010 | 06:21 PM
myyota's Avatar
The shackle angle in the front doesn`t look good, its almost touching the frame.
Old Jan 29, 2010 | 06:50 PM
Raybicon's Avatar
use 5" greasable shackles and throw away the stock ones.
Flying91
45
Apr 11, 2024 04:39 PM
Shagool22
Aug 14, 2015 12:24 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
