Corner bulb replacement
Old Jan 31, 2010 | 12:39 PM
BR06623's Avatar
90 4Runner - Need to know how to replace bulb in corner marker light/turn signal. Tried removing the two screws that hold the lens on but was not able to pull the lens.
Manual says remove the bulb and replace with same type bulb!! Duh!!
Old Jan 31, 2010 | 12:56 PM
iamsuperbleeder's Avatar
After you take those two screws out, pull the entire light assembly out and away to the side. It's held to the grill assembly with two prongs that kinda snap into two holes into the side of the grill. It takes a little force, and a little wiggling, but it'll pop out. Then just grab the bulb holder and twist it, and it'll pop out of the assembly, and you can pop in a new 194 bulb
Welcome to YotaTech!
Old Jan 31, 2010 | 12:57 PM
myyota's Avatar
Remove the two screws and work the corner light loose from the fender, twist the light socket loose from the light housing and remove the bulb. Replace in reverse order.
Old Jan 31, 2010 | 07:30 PM
BR06623's Avatar
Thanks for the information and the quick reply. Been checking out some of the discussion on Yotatech....Great website!!
I will try to fix the light tomorrow.
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
rushw
Jul 18, 2015 01:46 PM
madxman21
Jul 9, 2015 10:26 AM
coryc85
Jul 7, 2015 04:05 AM
