Noises
Old Jan 6, 2009 | 04:10 PM
Nothingbutyoda93's Avatar
Exclamation Noises
When i turn hard going foward or reverse i hear like a braking loose noise. Its almost like a tire rub but from the rear wheels??? and my tires dont rub their only 31's
Old Jan 6, 2009 | 05:26 PM
thook's Avatar
Are you sure it's from the rear? Know what bumpstops are?
Old Jan 6, 2009 | 05:34 PM
the_ocho's Avatar
there may be a mattress wrapped around your drive shaft
Old Jan 6, 2009 | 05:38 PM
abecedarian's Avatar
could be bunches of things- wheel bearing(s), differential, loose brake hardware... you may have a lsd or something in the rear causing one tire to drag when you're turning.
Does it make more noise turning left or turning right, or about the same?
Old Jan 6, 2009 | 06:02 PM
just when turning hard mainly how both ways. the fronts sometimes do it to.
its been a problem ever since i had the truck and nothing seems broke. but it gets old
i've had some ppl look at it and they said cv joint...
no whats a bumpstop
Old Jan 6, 2009 | 06:04 PM
the_ocho's Avatar
bump stops are what limits the travel of you axle. if your missing yours your tire may come in contact wiht your body or frame during axle articulation
Old Jan 7, 2009 | 04:30 PM
leebee's Avatar
turning hard and hearing noise makes me think steering stops?
lee
Old Jan 7, 2009 | 04:45 PM
thook's Avatar
Steering stops... that's the word. Thanks Leebee.
The steering stops/bump stops are on the lower control arms. They're crescent shaped and catch the large bolts that are on the bottom of the backing plate of the front wheels. Look and you should see them.
As said, they limit the turning of the front wheels so your tires don't rub the frame, body, or steering components. It's pretty common to be surprised by the noise they can make if one doesn't know they are there. They require frequent greasing and maybe even end caps if they are worn through.
Old Jan 8, 2009 | 01:05 PM
leebee's Avatar
no worries mate, i figured one of you young bucks would have come up with it before an old codger like me!
lee
Old Jan 8, 2009 | 01:19 PM
lee
Old Jan 8, 2009 | 06:32 PM
PERFECT
now where to grease
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
