power to front windows
Old Jan 5, 2009 | 01:11 PM
slowncurious-87's Avatar
Ive been trying to fix this problem for a while now I have found the power window relay under the ecu, and have checked the continuity from the switch to the inside harness. However I am not getting any power to this harness where does the power come from or how could I trace it? Thanks
Old Jan 5, 2009 | 02:34 PM
And I'm tired of blowin fuses so I need help!
Old Jan 5, 2009 | 02:39 PM
BigBluePile's Avatar
Well, what's the original problem?
I'd go by the wiring schematic and trace it that way. I'm assuming your have a 1st gen 4Runner. Originally on my pwr windows I couldn't roll up the passenger side from the drivers side, but everything else worked fine. I ended up having to replace the whole drivers side switch assembly.
Old Jan 5, 2009 | 02:42 PM
Well when I first got it the windows worked...kinda the passenger would roll down no problem going up different story the drivers side worked ok them just didnt any more either did the passenger side my locks work great but Im not getting any power to the switch. And its a 87' runner
Old Jan 5, 2009 | 02:53 PM
4runnerx3's Avatar
Old Jan 5, 2009 | 02:59 PM
My runner is different from the diagram. Does my power wires go to the relay that is located in the passenger side kick panel? crap, thanks for posting though.
Old Jan 5, 2009 | 06:20 PM
idanity's Avatar
very likely the switch.
get a double pole, double throw...= dpdt, about 2 bucks somewhere
try that, and if it is the switch, either rebuild yours or pony up the 2hundred dollar dealer one...(mines on a 2 dollar switch now, and it works fine...
looks like a turbo button, but i can at least raise/lower it from both seats...(till i find a good one).
hope that helps.
Old Jan 5, 2009 | 06:50 PM
If I run a power wire to the harness inside the switch works fine on the drivers side, so the switch is good but thanks for the advice.
Jun 1, 2021 01:51 PM
jasonty
41
Dec 23, 2018 01:00 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
coryc85
Jul 6, 2015 04:07 AM
