Pipe Help and Terminology
Old Jan 2, 2009 | 07:40 PM
parkkicks's Avatar
Question Pipe Help and Terminology
Hey all. starting to look at an exhaust system for my baby! i just have some questions about what kind of pipes i need and how much.
heres the plan so far.
The rig is an 87 22r reg cab pickup
LCE Header
2.25 pipes
magnaflow 14" round Muffler
Magnaflow High flow cat
so i guess im just wondering about the types of pipe available online.
what type of steel should i get?
thickness?
do i need to do any custom bending or can i get pre bent stuff online?
thanks for the great assistance i know you will give
Parker
Old Jan 2, 2009 | 07:51 PM
muddpigg's Avatar
sounds like an awesome set up. I'd like to sugest putting a flex joint on the down pipe. Don't know if I'd trust prebent pipe if you intend to wheel it as you'll want it tucked in tight. I had portion of mine down in Texas at a shop that only one guy spoke english great work for cheap but that don't help you. I went to Bucky's in Lakewood for the flex joint and befrore I knew it I was really screwed by his pricing. He had already had his man weld it into my down pipe so I couldn't just say keep it. I took the down pipe off the truck and did all the measurements myself. So beware Bucky's will get you over a barrel. Can't help much more.
Old Jan 2, 2009 | 07:59 PM
AP4CHE's Avatar
There'd be no point in ordering that stuff online except for the headers. You can buy all kinds of exhaust pipe at a lot of stores so why pay shipping and wait for it. Also, a muffler shop will do the bends for you, usually doesn't cost too much either.
Old Jan 2, 2009 | 08:00 PM
parkkicks's Avatar
so the down pipe is the collection pipe of the header (where the 4 tubes join to 1) where i would then add pipe correct? and i want to have the flex joint to prevent damage to the system from flex right?
thanks for helping a poor young noob
Old Jan 2, 2009 | 08:05 PM
parkkicks's Avatar
ya a local muffler shop quoted me for 225 bucks for pipes and install. i would rather not pay that much and do it with my friend and his welder. but ya i forgot about just buying the pipes at a muffler shop.
are there any strange bends i will need or can i just send a single pipe straight back from the flex joint?
Old Jan 2, 2009 | 08:56 PM
parkkicks's Avatar
oh or i was wondering if this would work
http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
Old Jan 2, 2009 | 09:01 PM
abecedarian's Avatar
that kit is intended for installing an "X" pipe in a V6 or V8 engine'd vehicle.
Old Jan 2, 2009 | 09:04 PM
parkkicks's Avatar
ahh thank you abe. i knew i read that to fast
Old Jan 2, 2009 | 09:12 PM
That sounds high. I had a converter, el-cheapo turbo muffler and 2.25" pipe installed in our '91 for ~250. This was a couple years ago though....
The flex pipe would go between the header / collector and the catalytic converter. Then you could go straight to the muffler. You'd need something to go over the rear axle and turn out the side if you want it 'stock' looking. You may be able to use a 45 to go up, then a 90 over the axle to turn back down, then 45 back to horizontal and 45 or 90 out behind the tire, or straight out the back.
Old Jan 2, 2009 | 09:18 PM
parkkicks's Avatar
Thanks abe! that was exactly the advice i was looking for!
im going to check out another muffler shop and see if i can get a better quote
thanks again
Old Jan 2, 2009 | 09:20 PM
muddpigg's Avatar
You can do a good portion yourself. I put header-down pipe-cat (direct fit flange put on should have ordered cat that way but didn't know I needed it that way at time, check your header)- pipe (like 12-18")- muffle (I'm running glasspack). Glasspack bent over axle to exit rear behind driver side tire paid to have bent 2.25" pipe. I got the rubber donut hangers and reused some of the stock hanger peices and bought some new ones too. You may be able to use your stock system as a template to have part of it bent for you. Just make sure everything will mate like you want. This is like the flex joint I got screwed over http://cgi.ebay.com/ebaymotors/2-SS-...spagenameZWD1V but of course you'll most likely want a larger diameter, price around.
Old Jan 2, 2009 | 09:22 PM
muddpigg's Avatar
If you wheel you may not want it coming straight out the back, it could make alot of ground contact on steep entry and exit angles.
Old Jan 2, 2009 | 09:33 PM
parkkicks's Avatar
off topic but abe what front bumper do u have on your avatar rig?
Old Jan 2, 2009 | 10:34 PM
IIRC, it's a Smittybilt. Came with the truck when I bought it. Beastly looking thing, eh?
Old Jan 3, 2009 | 08:18 PM
parkkicks's Avatar
ya its a bummer smitty stopped producing quality and went uner...
i really like that design and cant find anybody that makes something similar. i guess i will just have to scour craigslist for a used one.
kawazx636
Oct 6, 2021 03:03 PM
Obmi
Oct 4, 2015 11:30 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
gyroscope7
7
Sep 27, 2015 08:39 PM
larrys93pickup
Sep 17, 2015 07:05 PM
