Clanking Noise when in 4wd
Old Dec 31, 2008 | 07:13 AM
91FREERUNNER's Avatar
So I went wheelin a few days ago and got stuck.... Ever since then I have a clanking noise when in 4wd How do you check the CVs to see if thats what it is?
Old Dec 31, 2008 | 07:38 AM
abecedarian's Avatar
clanking?
first look at the cardan joint on the front driveshaft (the joint closest to the transfer case) and see if it's hitting the skidplate.
Old Dec 31, 2008 | 07:44 AM
what would cause that just a bent skid right? When i noticed it i was on the throttle pretty hard and the truck started to hop so i backed off...... Its a clanking you hear and you feel something a bump.....and obviously the faster the worse it gets.....
Old Dec 31, 2008 | 07:59 AM
4Crawler's Avatar
There is often a little piece of metal bolted to the transfer case crossmember that is easily bent up into the front driveshaft. First time mine bent, it rubbed on the front shaft in 4WD. Easy fix was to remove the two bolts holding it on and get rid of the bent piece.
Old Dec 31, 2008 | 09:54 AM
going to check it out now hopefully its something simple like that
Old Dec 31, 2008 | 02:43 PM
Well i just got it off the lift and found nothing but a fuel leak....so i took care of that.....I put it in 4wd and spun the driveshaft manually nothing no noise at all so its got to be when the truck is under a load nothing was touching the shaft either.... Im thinking front diff now
Old Jan 1, 2009 | 11:25 AM
any other ideas? It snowed here so im going to have to wait to do more investigating...
jashoeuh
Nov 18, 2024 08:08 AM
genuinegemini
Aug 3, 2015 04:56 PM
ahriman
Aug 1, 2015 10:38 AM
ripp96
Jul 25, 2015 02:32 PM
razorman8669
Jul 12, 2015 12:13 PM
