Just can't decide...
Old Jan 3, 2009 | 09:08 AM
MKW's Avatar
MKW
if 35/12s will fit on my truck or not. I have a 89 with a 4" suspension lift. I am running Soft 8s (15x8) with 4" backspacing. I bought 33s with the lift, but looking at it now, it looks like 35s will fit pretty easily. My truck basically stays on the street and I'm not willing to hack it up. I will pound the pinch weld if needed, but that's about it.
Sooo...will 35s fit with 4" of lift without rubbing??
Mike
Old Jan 3, 2009 | 09:12 AM
4banginRunner's Avatar
without ANY rubbing? no
my dads old 93 had a 4" bracket lift with 35s and on hard turns they would rub a bit
Old Jan 3, 2009 | 09:18 AM
tman12345's Avatar
maybe get BJ Spacers and something to match the back.
Old Jan 3, 2009 | 09:19 AM
x2, small body lift would work too
Old Jan 3, 2009 | 09:35 AM
abecedarian's Avatar
Considering 31's will fit with slight rubbing w/out a lift, and 35's only add about 2" to the radius of the tire, it shouldn't rub with a 4" lift... but you're going 12" wide ... so you may rub at full lock ... but you've got 4" b/s so that may pull the wheel in a bit to help. You may rub on the frame with that...
You are very likely to rub the rear if you load the back up and compress the springs enough though.
See if you can get the tire shop to mount two up front and have a look. A lot of shops will mount them if they're confident you're gonna buy if they don't rub. Discount Tire (I was on a budget) mounted my 31's up front (265/75r16 actually, before I did the suspension lift) to check if they would rub at full lock (which they didn't)... and even jumped up and down on the bumper to help check for rubbing .
Old Jan 3, 2009 | 09:41 AM
BigBluePile's Avatar
Yes, you'll be fine. I had to adjust the steering stops, but that was it. If you have 4" backspacing you'll be in better shap than I was with the 4.5" backspacing on my rims.
Old Jan 3, 2009 | 02:00 PM
MKW's Avatar
MKW
Oh, screw it...I'm getting 35s! Bottom line, I'm not happy with the way the 33s fit and it's only money, right? I'll make'm fit, one way or another!
Mike
Old Jan 3, 2009 | 03:03 PM
BMC's Avatar
BMC
Another thing to think about is gears. Have you already regeared or do you still have stock gears? 22re or 3.0? Auto or manual? Bigger tires on stock gears makes a huge difference.
Old Jan 3, 2009 | 03:06 PM
yea if you have stock gearing, its gunna be one hellva dog
Old Jan 3, 2009 | 03:47 PM
MKW's Avatar
MKW
I just finished putting 4.88s in today, so I'm good there. I've got a strong 22re with a 5speed.
Mike
Old Jan 3, 2009 | 04:31 PM
where's that 'balls to the walls' emoticon?
Old Jan 3, 2009 | 06:06 PM
MKW's Avatar
MKW
HaHa...yeah, I ain't scared!
Mike
87xjmike
Apr 4, 2012 11:20 AM
Jin_Chris
18
Oct 29, 2009 09:31 AM
4Runner_Girl_CO
Sep 21, 2009 01:10 AM
