time for a new driveshaft?
Old Jan 3, 2009 | 07:56 AM
Beaniam's Avatar
Since the SAS and lift I noticed a weird driveline vibration around 20mph and sort of a rattle/woosh sound when letting off the throttle at around 40-50mph.
Checked the driveshaft today and the ujoint caps are loose inside the driveshaft ears up at the transfer case. These have been like that since I replaced the u-joints but I didn't really think much of it. Now with the increased angle it's an annoyance.
I'm assuming these are supposed to be pressed in tight unable to move right? The ujoint is less than 4 months old but the old one had become so bad the caps were seized to the ujoint and were spinning inside of the driveshaft ears instead of on the bearings. If there any way I can tighten it back up again? Tack welds? Or just find a junkyard driveshaft?
Old Jan 3, 2009 | 08:04 AM
dbcx's Avatar
Havent ever had that happen before. I bet it did make some crazy noises if the cap was spinning inside the ends.They are pressed, not sure what you could do to tighten it back up without getting a new shaft. Is it a daily driver?
Old Jan 3, 2009 | 08:06 AM
algranger's Avatar
if the cap was spinning it probly wore down on the dshaft pretty good. id go get a new one at the junker and use your old ujoint
Old Jan 3, 2009 | 08:15 AM
Beaniam's Avatar
yeah that's what I figured. It's not my daily. I'll pick up another driveshaft and experiment with a couple light tack welds to hold this one in place for the time being
Old Jan 3, 2009 | 11:00 AM
Beaniam's Avatar
hmm... didn't think of that. thanks for that tip. I used a punch and peaned some of the inside of the ears then the caps pressed in tightly.
Old Jan 3, 2009 | 08:16 PM
Beaniam's Avatar
You know what I just realized today after 2 years which was pointed out by the guy I picked up a new driveshaft from today? Mine is on backwards. Slipyoke is by the 3rd member and the solid section is up by the transfer case. I don't know if that really matters but I'll switch it back around when I put the new one in.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
Poncho0206
Jul 10, 2015 06:21 PM
