What else do I need?
Old Dec 30, 2008 | 11:23 PM
91Toyota's Avatar
for my auto to manual swap.
Here is what I have:
Transmission - $100
Transfer case - $50
Flywheel - $25
Pedals - $25
Cross member (tomorrow) - $15
Need (what I know)
Clutch kit
Clutch master cylinder
Flywheel resurfaced
And is there anything else?
Also, what is that thing called that goes from the male end of the tranny to the male end of the transfer case (connects the two male ends so its a female piece)...I'm clearly missing it.
Pics...
Old Dec 30, 2008 | 11:33 PM
Bigblock's Avatar
Wash that stuff man!JK you need a coupler and a hole in the floor,LOL.
Bigblock
Old Dec 31, 2008 | 03:52 AM
Alex 400's Avatar
you need a master and slave cylinder.
Old Dec 31, 2008 | 07:10 AM
abecedarian's Avatar
http://personal.utulsa.edu/~nathan-b...nualtrans.html
Old Dec 31, 2008 | 07:15 AM
TNRabbit's Avatar
I think you'll need to swap out your ECU as well...
Old Dec 31, 2008 | 11:04 AM
91Toyota's Avatar
Okay thanks guys!
Got my flywheel resurfaced and got the x-member. Anyway, is the coupler supposed to slip in and out?
Old Jan 1, 2009 | 05:18 PM
91Toyota's Avatar
bump...need help with the coupler
Old Jan 1, 2009 | 05:22 PM
coupler?
Old Jan 1, 2009 | 05:43 PM
jsn_stockard's Avatar
12 pack
Old Jan 1, 2009 | 05:49 PM
myyota's Avatar
You do not need to change the computer.
Old Jan 1, 2009 | 06:16 PM
91Toyota's Avatar
Originally Posted by abecedarian
coupler?
Whatever the thing I need is called.
Goes on the back of the tranny to the front input shaft on the transfer case. Its pretty much just a sleeve. But of course, the link you gave me showed nothing.
Old Jan 1, 2009 | 06:57 PM
91Toyota's Avatar
Output shaft?
Old Jan 1, 2009 | 07:51 PM
91Toyota's Avatar
bump...because I looked through the fsm and didn't see anything about removing or installing...help!
Old Jan 5, 2009 | 03:17 AM
TNRabbit's Avatar
I thought a change in transmission required a different ECU to work properly...?
Old Jan 5, 2009 | 06:59 AM
91Toyota's Avatar
Supposedly not. Apparently you can simply jump the two wires (park) so you can start the truck. Other than that, I would think you could just leave the unused plugs unplugged.
