Belt tensioner
Old Jan 4, 2009 | 08:38 AM
wbthornton88's Avatar
Belt tensioner
Where is the tensioner for the last belt you put on on a 95 3zve. The pelt that goes around the pulley connected to crankshaft pulley and around the powersteering I think.
Old Jan 4, 2009 | 09:55 AM
neoworm0's Avatar
I don't think there is one. I usually just do it by hand and tighten the bolt. One thing I found helps is to use a slightly smaller belt (pelt) than the OEM one. I find if I use the OEM pelt the power steering pump hits the timing cover before I get it tight.
Old Jan 4, 2009 | 10:47 AM
xzyragon's Avatar
i have a 22re, but my two belts went around the AC and the Fan / Alternator
there was a separate tensioner for the AC belt, but the Alternator served as the tensioner for the second. I just leveraged it down with a piece of wood and tightened the screw up, tensioned the belt just fine.
Old Jan 4, 2009 | 10:50 AM
DeathCougar's Avatar
The PS pump IS the tensioner on the 3VZE. There is a bolt to loosen behind the pulley, and one down lower on the bracket. Then you apply tension just like on the alternator.
Old Jan 4, 2009 | 11:29 AM
I got it I just put it on the other to pulleys started wrapping it around the powersteering pulley and turning the crankshaft. It was as easy as putting on a bicycle chain.
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
Dale Johnston
11
Oct 31, 2015 10:22 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
