What is my rear end gear ratio?
Old Dec 29, 2008 | 10:43 AM
pillguy's Avatar
Hi all,
I have a 97 4runner v6 4x4 and need help with my final rear end gear ratio. The tag on the door says A/TM A03A/ A340F
One source tells me a 4.10.
Please advise
Thanks,
Old Dec 29, 2008 | 10:56 AM
Camach's Avatar
One way to check is to jack up the back end and and check how many times your tire turns in relation to your drive shaft.
If its 4.10 then your drive shaft will turn a little over 4 turns to your one wheel turn.
Turn your a larger number of times to get it more accurate. 20 wheel turns instead of 10. That kinda thing.
Old Dec 29, 2008 | 11:00 AM
trbizwiz's Avatar
you can call the dealership with your vin number and axel code and they might be able to tell you. You can also pull the drive shaft off the third mdmber, and there will be a color painted on the end, that will tell you too. I have no idea what color is what, but I am sure you could find it with a search.
Old Dec 29, 2008 | 11:27 AM
Camach's Avatar
Not to steal the thread but while we are on the subject of rear gears. How do you go about measuring the rear gear like as if you have it out and it is in your hands?
Old Dec 29, 2008 | 11:29 AM
Tofer's Avatar
Sponsor
divide the teeth on the ring gear by the number on the pinion.... 41/10 =4.10
Old Dec 29, 2008 | 11:33 AM
Camach's Avatar
I mean like telling if my rear gear is 7.5 or 8 inch? Is that just the diameter?
Old Dec 29, 2008 | 11:40 AM
Tofer's Avatar
Sponsor
2wd (5lug wheel) and IFS 3rds are 27spline 7.5"
any 4wd 79-95 is a 30 spline 8".
Old Dec 29, 2008 | 02:11 PM
iamsuperbleeder's Avatar
1st off, wrong thread section...
2nd, search.
not try'n to be a dick or N E thing...
Old Dec 29, 2008 | 02:42 PM
space-junk's Avatar
yes you are travis...
Old Dec 29, 2008 | 02:59 PM
ah, it happens sometimes
mskalmus
May 28, 2017 07:51 AM
icentropy
Jul 11, 2015 07:21 AM
icentropy
Jul 9, 2015 02:12 PM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
