93 4Runner brake work
Old Jan 2, 2009 | 11:16 AM
Bigscotian's Avatar
I just recently posted another thread about my 4Runners new starting problem, but it also needs some other TLC. I'm thinking of completely redoing the brakes, lines and all, and have priced all the parts. I'm just curious if anyone has done this before, how much of a PITA it is vs spending big bucks to have a shop run the lines.
I'm also facing the demise of my rear end suspension. My passenger side shock mount has broken free and the hangers are'nt looking so good either. I've seen some good ideas for the shock mount, but hav'nt come across anything for the hangers. If you have any pics or drawings of hangers you've made to remedy this problem I'm sure I could have a metal shop fab up the parts to be welded on. Thanks for any help.
Old Jan 2, 2009 | 11:27 AM
abecedarian's Avatar
most of it's fairly easily accessible... except for the lines to the rear / lspv which run along the frame next to the gas tank. if they're not corroded I wouldn't bother with them.
Old Jan 2, 2009 | 11:44 AM
PCE91V64x4's Avatar
On my truck the rear lines were in the worst shape so do check those. Overall what you want to do just takes time but is not to difficult.
I did a front brake job last weekend and it is straightforward, but you will want to have extra pins for the caliers ($2 each at the dealer, 2 per caliper) and use the old brake pads to compress the pistons in the calipers using a c-clamp (the FSM says to use a hammer handle).
As far as cost goes this job is way cheaper as a DIY than paying a shop or the dealer to do it.
Old Jan 2, 2009 | 04:22 PM
leebee's Avatar
those lines hidden by the gas tank will definitely be in dire need of replacing. no sense in doing the job half way, have at er bi!
lee
Old Jan 2, 2009 | 07:05 PM
Matt16's Avatar
Drop the gas tank, I hear its not a difficult job.
Old Jan 3, 2009 | 05:59 AM
Bigscotian's Avatar
Thanks for the info guys, I'm going to be dropping the gas tank to do the work on the rear passenger shock mount so I should be able to get in there. I'm also considering replacing everything, calipers, rotors, drums, wheel cylinders, etc. The cost to replace everything while I'm at it will still be 1/4 of what the shop would cost.
gillesdetrail
Nov 19, 2019 12:56 PM
voiddweller
19
May 2, 2016 09:10 PM
miceal383
Jun 29, 2015 12:27 AM
YotaGreenhorn
Jun 27, 2015 07:00 AM
gog1968
Jun 22, 2015 05:55 AM
