ugh, i need quick help
Old Dec 30, 2008 | 06:04 PM
SR5's Avatar
SR5
my truck is the most stubborn piece of s
im trying to get the drum off and their stuck on their, any tricks to get them off
Old Dec 30, 2008 | 06:07 PM
iamsuperbleeder's Avatar
thread some bolts into the tapped holes on it, then beat on it with a hammer, after getting through the little opening in the back and un-adjusting the brakes of course
Old Dec 30, 2008 | 06:08 PM
abecedarian's Avatar
adjust the shoes loose (http://personal.utulsa.edu/~nathan-b...tem/11-4wd.pdf step 3)
smack it with a hammer... or...find the threaded holes in the drum and run a couple bolts in...
edit- missed it by > < that much
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Loosen up the brake adjuster, and tap all around the drum with a hammer. Or put a large standard screwdriver between the drum and the backing plate, and twist it/pry back and forth some to get the drum to move.....
Old Dec 30, 2008 | 06:09 PM
SR5's Avatar
SR5
oh ya i forgot about the thread through trick, ok ill be back
99SR5's Avatar
smash it with a hammer and make sure the parking brake is off =)
Old Dec 30, 2008 | 06:10 PM
Originally Posted by 99SR5
...make sure the parking brake is off =)
That always helps too.
Old Dec 30, 2008 | 07:16 PM
SR5's Avatar
SR5
its coold wet and windy, and i am sick of my dam truck, it always does this to me, i go to do like a 5min thing, and it takes HOUUURSS to do, oh and my neighbor called the cops on me, because i severed ournd a peice of ice, and he thought i was trying to kill em,
so i quit........
SR5's Avatar
SR5
and yes i tried EVERYTHING mentioned above
Old Dec 30, 2008 | 07:54 PM
86Toyrunna's Avatar
possibly put some all-thread in thoes threaded holes and use a slide-hammer (or something to that effect) to try and bust em loose.. yea make sure that parking break is fully relased with all the cold wet weather us in the pacific nw have seen latley they may be froze up.. i felt like a damn idiot one day after beatin on mine for almost 2 hours just to realize i left the parkin break engaged lol
Old Dec 30, 2008 | 09:40 PM
SR5's Avatar
SR5
no i checked it, its off, i banned with a hammer, tried the threading through with bolts, and tried to loosen the brake from the back, and nothing, also tried hitting with brake cleaner, nothing
so im going to get a "free brake inspection" tomorrow, let them deal with it.
Old Dec 30, 2008 | 11:49 PM
Bigblock's Avatar
It wont be free after that one.LOL
Bigblock
Old Dec 31, 2008 | 10:51 AM
About 2 weeks after I first picked up my 91 the brakes started feeling REALLY soft, then I noticed fluid on the inside of my rear tires, and sure enough I was low on brake fluid.
So I go to tear into the job so replace the wheel cylinders and everything else in there, and when I went to remove mine, they would wiggle a little, but absolutely WOULD NOT come off. Screwed with it for 2 hours before thinking of letting slack out of the adjustment through the backing plate, and after fiddling with that for another 30 minutes, I managed to pry the things off. They were the original drums on the truck with 285k miles on them, and they had worn a groove so deep in them, that I'm convinced they would have ate through in the next 5 or 6 thousand miles... there was very little metal left...
needless to say, it also got new drums then too...
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
zytra
Jan 24, 2019 03:16 PM
charlie_fong
Sep 27, 2015 10:06 PM
