Stock ECU- what HP # is good for?
Old Dec 29, 2008 | 05:42 PM
Erik Beeman's Avatar
Simple question, like the title says....What is the stock ECU (88 22RE 2wd) good for in power perspective? Where does it draw the line, 150hp?
Old Dec 29, 2008 | 05:55 PM
abecedarian's Avatar
with stock injectors and no afm mod, about 130 would be a safe guess. it'll reportedly support a turbo up to about 3-5 psi boost. with a set of larger injectors and some afm recalibration, 150 is reasonable, but I think low-rpm drivability will suffer due to the cam required to hit that.
c'mon... tell us... what are you planning?
Old Dec 29, 2008 | 06:35 PM
.Ok ok ok.......
I THINK I'm planning a N/A motor, pumped out as fat as I can get it. Stock block, I'm going to start by boring it over. From there, just gooooooo for it. I have absolutely no doubt or argument with anyone on here, but I think that 200hp is very doable. Butttt, can't use stock ECU with a HI-PO motor. Run a stand-a-lone?
Ugh. There is so much to think about :crazy:
Old Dec 29, 2008 | 06:40 PM
for that, yeah I'd go stand-alone... probably either sds efi (http://sdsefi.com) or megasquirt (http://www.bgsoflex.com/megasquirt.html) with a MAF
SR5's Avatar
SR5
forget that, just get a 3.4L and SUPERCHARGE,and get up 310hp (i saw it in the last issue of 4WD TOYOTA OWNER )
Old Dec 29, 2008 | 06:42 PM
iamsuperbleeder's Avatar
whoa, that's a first... I've never heard anyone recommend that motor!
Old Dec 29, 2008 | 06:45 PM
SR5's Avatar
SR5
lol, smart
Old Dec 29, 2008 | 06:49 PM
Yeah, MS (MegaSquirt) is what I'm [more] familiar with. We use MS on the G45B Mitsu's like I've mentioned before.
kazuya2416
Apr 5, 2024 02:17 AM
lledwod
Aug 30, 2016 01:03 PM
DrZero
Jul 13, 2015 09:59 AM
crashburnoveride
Jul 10, 2015 06:39 AM
garagespace
Jul 9, 2015 08:37 AM
