Transmission Problems
Old Dec 29, 2008 | 08:38 AM
TNrunner92's Avatar
Ok well yesterday when I was driving home I noticed my truck was spraying transmission fluid pretty good. It’s a 95 4runner 3.0 Automatic tranny. I pulled over and looked at it. The hose that was spraying the fluid was broken, almost falling off. I fixed the hose to where it wasn’t leaking. I lost a lot of fluid, I’m not sure how much but A LOT. So I put about 6 quarts of transmission fluid in but I don’t know if that’s enough. And I took the hose off to see if fluid had flowed through it but none had gone through. After that when I tried to put it gear it didn’t pull. Like when I put it in “D” it wouldn’t move, I gave it some gas but it just revved up. It did the same in every other gear.
It may seem like I don’t know much because honestly I don’t. Haha. I am only sixteen and I have tried to explain the problem the best I could. Any help is appreciated.
Old Dec 29, 2008 | 08:39 AM
874runnersr5's Avatar
same thing happened to my friends auto tran in his heep, he ended up frying it up. Same thing would happen to, put it in gear and all it would do is rev
Old Dec 29, 2008 | 08:43 AM
TNrunner92's Avatar
I was thinking thats the problem...
Old Dec 29, 2008 | 12:02 PM
GorgeRunner's Avatar
Which hose was broken, the coolant lines to the radiator?
Old Dec 29, 2008 | 12:57 PM
abecedarian's Avatar
even if the trans was toast, one would think the pump would be circulating fluid.
Liadrin
Apr 25, 2022 02:54 PM
Liadrin
Sep 1, 2015 06:44 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
