4runner running alittle warm
Old Nov 10, 2011 | 01:24 PM
Gracies4runner's Avatar
Hi all thank u to everyone who helped me on my last post so I have a 95 4runner 3.0 man tran. Yesterday mY truck overheated found I had a loose upper radiator hose. So all the way home my truck would get a little warm not like overheating warm but warmer then what it should run at then it would.come back down some then back up the radiator is completely full has new water pump like 3 month old do u have any ideas
Thank u. Gracies4runner
Old Nov 10, 2011 | 02:17 PM
Scenic WonderRunner's Avatar
You may want to start by replacing your Thermostat.
Very cheap part.
They can get tired and stop opening up all of the way when your engine is at operating temp.
Old Nov 10, 2011 | 02:22 PM
Thank u for ur help I am going to try that
Old Nov 10, 2011 | 04:16 PM
I checked the thermometer it opened at 180f degrees do u have any other ideas drained the coolant no oil and oil styck is clean oil
Old Nov 10, 2011 | 04:31 PM
rworegon's Avatar
Fan clutch not working properly?
Old Nov 10, 2011 | 04:35 PM
Hi thanks for your post I willlike do research on it I no the fan is constantly turning
Old Nov 10, 2011 | 04:47 PM
rworegon's Avatar
Yes, it will constantly turn when the engine is running, but is it fully engaging when engine is running warmer than you would like?
One way to test >>>>>> BE CAREFUL <<<<<<<< Roll up a nice thick stack of newspaper and when the engine is running and up to full temp, see if you can easily stop the fan from spinning with the rolled up newspaper. If you cannot stop the fan blades, fan clutch is likely ok. If the blades stop easily, bad fan clutch.
Also, when the engine is cold give the fan blades a spin by hand....the fan should spin with noticeable resistance.
Old Nov 10, 2011 | 04:49 PM
OK thank you I will give that a try
ZXT
Sep 1, 2015 09:23 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
marcusSRG
Jun 27, 2015 07:13 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
slider417
Jun 22, 2015 10:18 AM
