Guages dont work after bulb replacement
Old Nov 7, 2011 | 06:54 AM
Scottyh's Avatar
I pulled the whole dash apart to replace various bulbs, change the stereo, new cig lighter and guage bulbs. It s a 1989 limited edition 4x4 extended cab I've had from 70 miles on it to 360k now. It wants to die but I keep resurecting it.
Now the tach, oil, and battery guages wont work. I've checked all the fuses and pulled it apart again to look for loose or missing wiring harness connections and it all seems fine.
thoughts?
Also, my power windows won't roll down.
Old Nov 7, 2011 | 07:03 AM
Scottyh's Avatar
ok, i was wiggling fuses and found if i pull the whole white plastic fuse housing toward me the gauges would work and windows roll down, anyone experienced this?
Old Nov 7, 2011 | 01:16 PM
habanero's Avatar
To my untrained readers it sounds like somewhere there is a loose connection and when you pull on the fuse block it moves the wire and completes the circuit. That moving the block causes the better connection doesn't mean the problem is in the block itself, though.
Old Nov 7, 2011 | 01:31 PM
Scottyh's Avatar
I found the problem. I had a fuse connector that allowed you to get power for lights, etc, it slips over the fuse blade. I had removed it so the slot was wider and causing a short. I found the problem by pressing on each fuse leg separately.
Old Nov 7, 2011 | 03:51 PM
habanero's Avatar
Cool! Thanks for the update, I was curious.
Scotttekoch
23
Nov 1, 2021 12:41 PM
gillesdetrail
Nov 19, 2019 12:56 PM
the1998sr5
Oct 19, 2016 12:48 PM
voiddweller
19
May 2, 2016 09:10 PM
gog1968
Jun 22, 2015 05:55 AM
