Need help replacing front lug studs
Old Nov 14, 2011 | 06:24 PM
22repower's Avatar
My valve stem was leaking so I took my 93 to my buddies house to get her fixed, got that fixed and went to put the wheel back on and BROKE 3 STUDS IN A ROW!!!! One with the impact and two by hand. The other three didn't get cranked down after that, so now it's stuck about ten miles from my place.
So I find this thread
https://www.yotatech.com/forums/f116...-stuck-195351/
WOW.... This doesn't look like fun
What do you guys think I should do
Old Nov 14, 2011 | 06:26 PM
waskillywabbit's Avatar
I'd get six new wheel studs and replace them all while you are there.
I'd check the rest too.
:wabbit2:
Old Nov 14, 2011 | 06:39 PM
22repower's Avatar
Yea I know they'll have to be replaced
I was hoping you guys might have some tips to chime in
That other thread makes it look way harder than it should be
Old Nov 15, 2011 | 06:27 PM
22repower's Avatar
Tore into it tonite
Here I got 4 out of 6 cone washers out from about 50 hits apiece with a hammer and screwdriver
Took a little break, pryed the gaps, and with about about 100 more taps each got the last two
12mm bolt, snap ring, and 54mm (i think) nuts came off fine
I had to unhook the brake line because it was hard line, but the caliper came off without a hitch, and now were bare!
Got everything separated, now I just need to pick up some studs tomorrow....
And at least I know why they broke:
Is it normal for those to wear like that? I'm assuming they are the originals from 93
One last thing, the one on the right came out of a 94 and seems a bit thicker than the ones that came out of this truck, is that right (the 94 was built in japan and 93 in US if that matters)
Old Nov 15, 2011 | 06:32 PM
22repower's Avatar
Also, how do I go about torquing the preload on the inner nut and lock nut, and the washer that goes between them
Old Nov 16, 2011 | 06:10 AM
22repower's Avatar
Anyone?????
lledwod
Aug 30, 2016 01:03 PM
ItsJustD
Jul 7, 2015 07:49 AM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
