Surging throttle and black smoke
Old Nov 5, 2011 | 10:20 AM
Jared7467's Avatar
I just got a 1991 4runner with the 3vze engine. I replaced the head gaskets and got it all put back together. i am having a throttle problem, when i am at highway speeds (55-65) and about 10-20% throttle the engine surges from about to 1200rpm to 2000rpm. Could this be a dead spot in my TPS? Also i have black smoke coming out of the exhaust pretty noticeable at idle. NO check engine light, other than the 2 problems listed above it runs great! Any and all suggestions are greatly appreciated. You all ROCK on this site!
Jared
Old Nov 5, 2011 | 10:31 AM
MortonPhotographic's Avatar
I can't say for your engine for sure... but my 22RE had throttle issues like that and it was a bad o-ring at the throttle adjust screw on the throttle body. Look for a vaccum leak anywhere, especially around the throttle body.
My smoke almost completely went away when I put a new disptick in, sealing the crank case. Make sure you don't have any crank case ventilation issues--oil cap, PCV...
I am no expert, and never worked on a 3vze, so please keep that in mind! Good luck!
Old Nov 5, 2011 | 10:39 AM
turkey's Avatar
where is the pcv valve on the 3.0 passenger side?
Old Nov 5, 2011 | 10:48 AM
Jared7467's Avatar
PCV valve is under the intake manifold, You should have a hose going from you intake plenum to it on the back side. i can take a picture if that would help.
Old Nov 5, 2011 | 11:14 AM
vasinvictor's Avatar
My thoughts are that you have a hose disconnected somewhere and making the computer see a lean condition, thus compensating with more fuel (hence black smoke) The TPS is easily testable http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml Also check your bigger rubber intake boot that connects silencer to the throttle body. They are usually cracked near the TB allowing extra air to enter after VAFM.
smthwsn357
May 1, 2024 07:28 AM
yota_Q
Oct 5, 2015 12:30 PM
accuracy
Aug 30, 2015 09:47 PM
bighaydn
Aug 4, 2015 07:17 PM
mikeyd6789
Aug 4, 2015 11:51 AM
