to replace or to not replace: 3vze head gasket
Old Nov 15, 2011 | 10:08 AM
alfio's Avatar
hello all
some time ago i picked up a '94 toyota pickup, 3vze with an R150F but with a bad head gasket.
the truck has high mileage (250+) but the PO said engine had been recently rebuilt (seemed like an honest guy) and the body is in good shape for indiana. i was going to keep it as a work truck but things have changed and it's gotta go.
now, i don't know much about the 3vze and have never done a head gasket one one. do i put in the work and get it running again so it will sell for more or put it up for sale as is?
i had a bad experience rebuilding a 22RE a few years ago and i don't want to repeat that... basically, i replaced the head gasket but the motor had the dreaded timing chain wear so i wasted lots of time and cash. i guess what i am asking here is exactly how many gremlins am i looking at if i go for the head gasket replacement? advice on this would be much appreciated
Old Nov 15, 2011 | 10:16 AM
skypilot's Avatar
I would do a 3.4L swap. I made the mistake of getting a 3.slo for my truck because ithought it was a decent engine. well it costs a lot of money and effort in parts to make it work and its just not worth it.
If its got to go, sell it like it is.
Old Nov 15, 2011 | 10:28 AM
alfio's Avatar
yeah, i know, it would be a different story if it was a keeper (but i already have another!).
i'm not afraid of the work and the head gasket kit is not too bad ($250) but i am concerned about running into other unknowns and then being stuck further up the proverbial creek...
thanks for the advice
Old Nov 15, 2011 | 11:55 AM
JohnVH's Avatar
you never know until you open it up I guess. Id say do the HG job.
Old Nov 15, 2011 | 12:10 PM
MudHippy's Avatar
Pretty simple in terms of head gasket replacement. I've done it several times now without any hickups. A lot a folks seem to have trouble when it comes to plugging everything back in and/or where it's supposed to be plugged in. Lots of vacuum hoses, fuel lines, coolant lines, and so forth that need messed with to get the heads off/on. And the removal/installation of the exhaust crossover can be troublesome(many methods to attack that issue...search). But other than that, if you're methodical about it, follow the procedures/specifications in the FSM, and take your time instead of rushing through it so as to minimize the chance of making mistakes, it's not that difficult at all really.
EDIT: Almost forgot, there's a chance you might struggle with the timing belt. As in getting the belt installed with the cam timing marks all lining up perfectly, not uncommon. And/or the engine not wanting to start after putting it back together because of installing the distributor 180° out, also not uncommon. I've never ran into these or any other problems. But I'm not exactly stupid or attention-defficient either, so I tend to not screw up as much when it comes to things requiring a good deal of common sense and careful attention to detail.
Old Nov 15, 2011 | 12:43 PM
blake.nemitz's Avatar
agreed mud hippy
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
