motor swap from 95 4 runner to 87 4 runner
Old Nov 4, 2011 | 09:12 AM
stonepoints's Avatar
A recent turn of events left my 95 4 runner upside down in a ditch on the side of the road (I avoided hitting the person driving the wrong way on my side of the road head on.) I have access to another 4 runner an 87, wondering if the engine (both 3.0) can be changed FROM the 95 INTO the 87, both have the automatic tranny. Any suggestions, thanks in advance for any help provided.
Old Nov 4, 2011 | 09:42 AM
waskillywabbit's Avatar
87 did not come with a 3.0
:wabbit2:
Old Nov 4, 2011 | 10:14 AM
Yes, the 87 has the V-6 (may even be a newer model year, it has the 4 doors, and I think that was 88 and later. The person who has it thought it was an 87, just going by that. Thanks
Old Nov 4, 2011 | 10:19 AM
3.0 V6 88-95 4Runner
Probably easiest to swap everything over including ECM as plugs and such surely changed 88 to 95.
Tell them it can't be an 87 too.
:wabbit2:
Old Nov 4, 2011 | 10:25 AM
Already planned on telling them about the year, I suspect that I can verify that off the vin #. Plugs were my main concern, I might get lucky if they are both second generation. 89 - 95. I could use some luck after rolling that on last Friday night. THanks again
Old Nov 4, 2011 | 10:44 PM
4wd4fun's Avatar
I'm interested in these trucks and did some googling. You wont need to check the vin, I think you can check the chassis code stamped on the frame behind the right front wheel: RN= 22re, VZN=3vze / v6
wikipedia says 1987-1997 - 3.0 L (2958 cc) 3VZ
Old Nov 5, 2011 | 12:36 AM
daved5150's Avatar
x2 on what the Wabbit said. The first year for the 3.0 was 1988 in the 4Runner.
*Rabbit: "Uh... yeah, trust me. Rabbit is good, Rabbit is wise."
*A character from the movie "Twister."
Old Nov 5, 2011 | 01:02 AM
4wd4fun's Avatar
"Hi my friend has a 1987 Toyota 4x4 1/2 Ton Xtra Cab truck with the 3.0l 3vze v6 motor,"
https://www.yotatech.com/forums/f2/1...uestion-43684/
"He shouldn't have that hard a time the 3.0 was a "Special Order" option in '87. Hamer Toyota out here in So Cal $120. "
https://www.yotatech.com/forums/f2/1...84/#post435852
Old Nov 5, 2011 | 02:56 PM
RatGDH's Avatar
The early 3.0 was 11/87 to 8/88 with a totaly different motor mount, I know I am trying to find the early mount for my motor! But the later motor will bolt right in using it's mounts, If you do have an '87 or early 88 want to get rid of those mounts?
Old Nov 5, 2011 | 07:44 PM
BlackNite3's Avatar
4 doors would make it at least a '90.
Old Nov 5, 2011 | 08:03 PM
CitrusTheDragon's Avatar
I was wondering if I was the only one that noticed that one
Old Nov 6, 2011 | 01:12 AM
daved5150's Avatar
Wow, I didn't notice that one....I'm usually at work doing this....and I'm usually pretty beat Oh well.
Old Nov 6, 2011 | 03:01 PM
Hadmatt54's Avatar
ToyDIY.com backs this date up as well, but wouldn't 11/87 be considered the 88 model year? This is November 2011 (11/11) and the 2012 trucks...if they are not on the dealers lots now they will be at very soon.
Old Nov 6, 2011 | 05:28 PM
still doesn't fix the 4door issue. Which makes it at least 91
Old Nov 6, 2011 | 07:14 PM
streetlancer's Avatar
4 doors would make it at least a '89.
There were some made in late 89
Old Nov 6, 2011 | 07:32 PM
late 89 would make it a 90's model
Old Nov 7, 2011 | 02:04 AM
Hadmatt54's Avatar
Actually,I believe it makes it a 90. You could get a 90 in either 2 or a 4 door model.
Old Nov 7, 2011 | 02:13 PM
Thanks everyone, Not been near the computer for a few days, hopefully I'll make it over this week to verify the year, and get a good look at the thing. All is appreciated
Old Nov 7, 2011 | 03:10 PM
Good point
Old Nov 8, 2011 | 12:24 PM
My guess is 91 or 92. Manf. I.D. Plate has it as 07 / 91. Yes I did discuss the year with the owner. He was going to look for the title to see what it says. Either way, I'm pretty sure that the engine and "brain" from the 95 will swap without a lot of issues.
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
ACZR
Jun 23, 2015 07:55 PM
infinityisfive
Jun 16, 2015 06:51 PM
