Bad u-joint solved the noise in the drive train
Old Apr 6, 2011 | 04:02 PM
anthony1's Avatar
I had a noise that sounds like metals scraping. It tuned out that my rear u-joint is frozen on one way. I replaced it with a lifetime one from Autozone. I hope it works well. Anyone have experience with Autozone U-joint?
Old Apr 6, 2011 | 04:35 PM
MudHippy's Avatar
Kinda sorta. I bought one once. Tried to install it, and it didn't quite fit. I could have made it work with the right size(thicker) snap rings/c-clips. But being thoroughly annoyed at that fact(and another...see below), I removed it and tossed it in the scrap heap. Then went to NAPA and bought one that I already knew would fit. Because I'd used them a couple times prior.
I'll never buy anything but Precision u-joints from now on. OEM are better, but at $55+ each...their not exactly in my price range. I can replace them with Precision u-joints 3 times for that amount of money.
BTW, did you happen to get the greasable type? Have you realized yet that you can't fit a grease gun on the zerk fitting with the u-joint installed. That's what really sealed the deal for me. Autozone u-joints SUCK!!!! I wanna beat the guy who designed them over the head with one...REPEATEDLY. If you catch my drift...
Oh well, good thing it was super-cheap I guess.
Old Apr 6, 2011 | 04:41 PM
anthony1's Avatar
It was 15 bucks with lifetime warranty. I guess I could've gone with the dealer. ( I know someone in the parts dept.) I also found MarlinCrawler sells the one he got from Japan for 25. I'll see how long this one last.
btw, I paid a mechanic to change it out after I took out of the truck for 25 bucks. I did marked it so it goes back the same way.
Old Nov 6, 2011 | 05:50 PM
1996Tacoma's Avatar
I have the same problem. Grinding metal on metal noise, vibrations, clink/clunk noise when going in to reverse and taking off.
Is replacing the u joint a difficult job? I will need to do this right away
Old Nov 8, 2011 | 09:21 AM
Cody91's Avatar
Its a Pain if you don't have a vice or torch but if you do it's cake just did it at work yesterday
Old Nov 8, 2011 | 09:23 AM
yotasavg's Avatar
I had crazy noises for a while too, new u joints ftw! quiet sailing now, minus my raging exhaust and loud tires....
Old Nov 8, 2011 | 10:17 AM
TNRabbit's Avatar
I don't understand all the trouble with u-joints; I still have my originals, and have kept them greased regularly, for over 265,000 miles now...
Old Nov 8, 2011 | 10:58 AM
snobdds's Avatar
Same here. I took off the drive shaft this weekend to replace the pinion seal and TC output seal and the U-joints were like new.
Old Nov 8, 2011 | 01:32 PM
monoman's Avatar
Previous owner of my truck installed (incorrectly) a Trail Master 4" suspension lift years ago and neglected to grease the U-joint fittings. When I bought the truck 2 years ago I noticed the lag and noise of drive into reverse and shifting gears so I replaced mine (nappa) and when i pulled the driveline and to swap them out i discovered that the U-joint had almost completely failed. 2 of the 4 caps were completely ground down to and past the studs under the caps (there were no caps left!!!) so it was kinda like the studs were clunking around the ears of the driveshaft... Crazy! I have seen a lot of failed u-joints in my days but this one was almost unrecognizable as a ujoint, just looked like a ground up chunk of steel.
So.... grease your U-joints and ALL your chassis regularly and they should last the life of your truck. FYI, lifted truck = extra stress and wear on U-joints. I recommend inspecting and greasing them every other oil change, ESPECIALLY with cheap'o brands.
Charecter1
Nov 6, 2023 10:08 AM
mskalmus
May 28, 2017 07:51 AM
smiley52
Jul 11, 2015 05:16 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
