Heater fan
Old Aug 19, 2009 | 08:23 PM
cdextreme's Avatar
Heater fan
Did a search alread and came up with pretty much nothing. The fan was started to work on only a slow speed (so I believe the resistor is probably ok) and now the a/c switch doesnt come on, neither does the fan. I have power at the one fuse on the right side labeled rr fan (and the rear fan works). No power at the a/c fuse (with fuse pulled and checking power wire). Am I missing a main hvac fuse?
Old Aug 19, 2009 | 08:50 PM
abecedarian's Avatar
maybe the switch is going?
Old Aug 20, 2009 | 04:50 PM
cdextreme's Avatar
Got heater motor to work. found a relay that was badly corroded from a leaking windshield. The relay I changed was the on closest to the passenger seat. I just swapped it with the one next to it. Any idea what the other one is for?
kawazx636
Oct 6, 2021 03:03 PM
woodyth
Sep 30, 2015 06:32 PM
voiddweller
Sep 28, 2015 11:21 PM
Matthew Perez
Sep 28, 2015 05:43 PM
--Oz--
Sep 6, 2015 01:06 AM
