Thing on top of the valve cover (picture)
Old Aug 13, 2009 | 02:33 PM
Junkers88's Avatar
So I was thinking that it was strange that my rear main just suddenly started leaking and decided to replace the PCV valve and grommet just in case it was plugged. I can't tell if the leak has stopped yet but I don't see any new drips.
Anyway.... while I was messing with the PCV thing with the engine running I noticed two things.
1) There was a freaky sucking noise that came and went.
2) When the noise was present the idle would drop and get rough.
I tracked it down to this tihing. (in yellow)
Now if I pull this hose off (again in yellow) and plug it with my finger then the idle gets smoother I still have some slight miss but it's less apparent when I plug this hose.
So what is that thing and what does it control?
I tried to search for it but I don't know how to look for pictures.
Old Aug 13, 2009 | 02:54 PM
iamsuperbleeder's Avatar
that would be the AC idle up solenoid, and the two hoses run over to the idle up valve
why it's screwing up the idle though, I dunno
I CAN tell you that when the valve is not in use (ie the AC is not turned on and running), it is essentially a controlled vacuum leak, and the plastic black cylinder looking thing on the end has a small filter element in it
Old Aug 13, 2009 | 03:12 PM
abecedarian's Avatar
The cap / filter on the end of it allows it to equalize pressure internally so that when the valve is turned off, it doesn't get stuck in the 'on' position by vacuum in the tubing.
The "controlled vacuum leak" is the valve on the side of the manifold which sources air from in front of the throttle plate in order to provide a metered source of air (air goes through the AFM so the mixture isn't affected) when the idle speed is raised by that VSV or by the power-steering unit.
If you're getting air being introduced to the engine through the cap on the VSV, there's a good chance that the unit on the manifold is malfunctioning, allowing vacuum up the hose it shouldn't be or the VSV itself is getting stuck 'half-on/half-off'.
Old Aug 13, 2009 | 04:04 PM
93YotaGuy's Avatar
Try switching the hoses around for the ac idle up valve and see if it works. I had mine flipped around and it was making that noise. Switch the hoses and you should be fine
Old Aug 13, 2009 | 05:34 PM
Junkers88's Avatar
I tried that and the idle was dead level but I wasn't sure if it was something I could run like that, you know..... change something and ruin something else. I have a 3 hour trip planned for tomorrow to do some fishing and didn't want to kill anything. On a side note I did spend about 2 weeks re-running the jacked up vac hoses from the guy I bought it from so it may have been crossed all this time.
I don't really understand the vacuum routing on this thing.......... so many hoses.
So if I switch the hoses and it runs better should I do it? I did a hose re-run a few weeks back and actually lost the codes for the O2 sensor and the EGR (no more CEL) but the CEL for the EGR came back with the odd miss at idle.
Old Aug 13, 2009 | 05:39 PM
myyota's Avatar
Just switch the hoses, it won`t hurt anything.
Old Aug 13, 2009 | 05:44 PM
BigBluePile's Avatar
You could shoot it...
Old Aug 13, 2009 | 06:01 PM
Junkers88's Avatar
Yeah but then your competition would be gone......
How would David feel if someone shot Goliath? Yup....... that's how you'd feel............................
Lost, Confused, Upset and lost in history as the guy that might have out wheeled my runner.
Oh did I mention I'm going fishing in the morning? *hugs*
Old Aug 13, 2009 | 06:04 PM
that's always an option
like the old saying, "If it doesn't fit, force it. If it breaks, then it needed to be replaced anyway"
Old Aug 13, 2009 | 06:05 PM
ROTFLMAO!!!!!
Fishing??! Man, I gotta go to work. Plus, I took the bumper of my truck so I'm down for a while anyways...
Old Aug 13, 2009 | 06:15 PM
93YotaGuy's Avatar
I just looked on mine and you do have it the wrong way.
Also I think when it is plugged in wrong the AC Idle up valve doesn't work.
Easy fix to re-route the hoses
Old Aug 13, 2009 | 06:25 PM
Junkers88's Avatar
Like that head gasket?
Just kidding man! Just kidding!!!
Old Aug 13, 2009 | 06:26 PM
93YotaGuy's Avatar
Haha that was COLD!
Old Aug 13, 2009 | 06:33 PM
ouch...
...funny though!
Old Aug 13, 2009 | 06:34 PM
Junkers88's Avatar
ROTFLMAO!!!!!
Oh so a bumper is going to stop you from wheeling?
FYI work is something you do to live, don't live for work...... you'll die old and pissed off with a pile of money for the kids (or in my case for the EX). Dude take your days and run with them, fish, hunt, wheel, live and love life.
God gave you the gift of life. Take that gift and run with it. You should not show up at the gates of Heaven in a clean suit, with no scars and smiling. You should slide into those gates on your ass with a half finished beer in one hand and a fishing rod in the other and exclaim "Damn that was one hell of a ride!!!!!" Live like you have no future.
Junkers88 3:17 states "No one else can step into your shoes and smile as much as you have".
Old Aug 13, 2009 | 06:46 PM
Well, yeah, it could.
Old Aug 13, 2009 | 06:57 PM
Shoooot, no doubt!! You get one shot at this so GIT-R-DUN!!!!!
Actually, the kids and I('cause the wife has been onboard the USS Ronald Reagan since May and "might" be back November...) are takin the weekend off because we've been out and about almost every weekend doing something . Next weekend I'm probably going wheelin though! Besides, if 380,000 of us decide not to go to work tomorrow then there's no Air Support for the guys on the ground somewhere.
Go Navy
BTW, thanks for the pay check!!!!
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
msane99
Jul 11, 2015 08:08 PM
icentropy
Jul 9, 2015 02:12 PM
Gamble_STi
Jul 7, 2015 07:54 PM
