Update -- Why Crank didn't turn when finding TDC
Old Aug 20, 2009 | 04:32 PM
larrys93pickup's Avatar
All,
this is an update to my previous post "87 - 22r TDC with head off ??"
The reason why I was unable to turn the crank over when finding TDC, before I took the head off. THE FREAKEN TRANSMISSION WAS IN GEAR!! This was why I had a bitch of a time trying to rotate the crank.
It was not because of a bad valve, in fact I talked to the machine shop guy today, the valves were replaced because they were too thin to get the proper grind.
So, I'm going to continue and rotate the crank, with the cam sprocket held up high, as to remove the slack from the chain, till I see the shiny link on the dimple of the cam sprocket, the zero on the timing gear, and the top of piston one flat with the top of the block.
Next time, I will always check to make sure the Freakin car is in neutral...
Lates,
larrys93pickup
Old Aug 20, 2009 | 04:50 PM
iamsuperbleeder's Avatar
lawl
don't cha hate it when ya do stuff like that
Old Aug 20, 2009 | 04:54 PM
yoterr's Avatar
haha, that sucks, at least you figured it out with no harm, i figure out stuff like that by it breaking
Old Aug 21, 2009 | 08:08 AM
Karlton's Avatar
Haha. And remember not to leave the wrench hanging off the end of the crank when you go to start the motor. Been there, done that.
Jun 1, 2021 01:51 PM
Ichneumon
Sep 27, 2015 04:21 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
toyota32
Jul 6, 2015 05:42 PM
rbravo1
Jun 29, 2015 01:34 PM
