tie rod problems
Old Aug 16, 2009 | 01:14 PM
Tattoo Mike's Avatar
tie rod problems
i have a 95 truck need to replace all my tie rods. removed pin and nuts on each tie rod i tried useing fork tool to remove them and was not able to move them at all. so i went out and bought an air hammer and tryed that. i all so tried puting a jack on the stud of tie rod putting the weight of the truck on it and the useing the air hammer and it stiil will not break free.please some one have any ideas on how to get theses tie rods off?
Old Aug 16, 2009 | 08:18 PM
tc's Avatar
tc
Pitman arm puller and impact gun. Spray it down with some PB Blaster the night before.
Old Aug 16, 2009 | 08:53 PM
OutlawMike's Avatar
Harbor Freight sells various tie rod tools. They are not much money.
Kragen rents tools, they may have one you can rent.
I have never found the fork to be worth a damn compared to the dedicated tie rod end/ball joint tools.
Kragen tool:
http://shop.oreillyauto.com/productd...egoryCode=3492
Old Aug 16, 2009 | 09:11 PM
Jay351's Avatar
Buy a tie rod end puller. Bout $25 or so at harbor freight.
I got one, I have used it so many times. Makes those things a breeze. Tighten till its super tight then giver a whack with the hammer.
Old Aug 16, 2009 | 09:32 PM
Plumbrbob's Avatar
X2 thats how I do it the fork does nothing
Old Aug 17, 2009 | 03:04 PM
tc's Avatar
tc
Originally Posted by OutlawMike
Kragen tool:
That's what mine looks like, but the package says "piman arm tool".
Old Aug 17, 2009 | 03:20 PM
yoterr's Avatar
i just did mine the other day..had no probs getting it out just hit the stud with a BFH a couple times and out she came, the real fun is trying to get them out of the adjuster deal....thought i was gonna keil over...also did you go with the ebay tie rods?? i have a slight issue with mine wonderin if you have the same?...
Old Aug 17, 2009 | 03:49 PM
Jay351's Avatar
I have one like that, and then a biger longer one with a pivot at the end. So you can put it as wide as you need it.
Best $30 I ever spent! A few of my friends who claim to never need such a thing have borrowed it a few times
Old Aug 17, 2009 | 09:16 PM
OutlawMike's Avatar
Doesn't that figure. I have friends like that too. Maybe we have the same friends? They get all macho, you don't need that, just do this. But, then, when they go to do it, guess what they are borrowing?
Old Aug 17, 2009 | 09:19 PM
Jay351's Avatar
Heheh, I just laugh Then they owe me
Old Aug 18, 2009 | 07:26 AM
crafthorse's Avatar
I just used the forks, and a 5lb sledge hammer. No problems, never had to have anything else for tie rod ends. Pitman arms on the other hand, I have a puller, they can be tight as heck.
Old Aug 18, 2009 | 03:07 PM
tc's Avatar
tc
On our Toyotas, they're all the same size, so why not use the pitman arm puller anyways? Much safer and better for the truck, especially if you need to reuse that TRE because the puller won't tear the boot like the pickle fork likely will
Old Aug 18, 2009 | 04:16 PM
just whent to harbor freight and the didnt have a tie rod end puller but the had a front end service set so i got that cost me $100 but well worth it. it has five different puller i'll find one that will work. and i didnt get my tie rods from e-bay baught moog brand tie rod ends,i baught moog brand pitman arm and idler arm so i whent with the same brand for my tie rods.going to work on my truck now so i will let you know if i have any probems with the adjusters later.
Old Aug 18, 2009 | 04:52 PM
yoterr's Avatar
sweet. 100 bucks is kinda steep but i guess you can use them for all sorts of things, i was just woundering about the ebay tie rods cuz it seems that my outer tie rod is shorter than the new one, wouldent make that much of a difference but their touching inside the sleeve
Old Aug 19, 2009 | 05:54 PM
just finished had no problem with useing puller thanks.have another problem test drove truck it drives fine until i get to 40 the steering wheel shakes even worse but it stops at 50. is this my tires or ball joints
Old Aug 19, 2009 | 06:34 PM
crafthorse's Avatar
I could not find my puller intill it got uncovered after I had already replaced the TRE's.
Old Aug 19, 2009 | 07:08 PM
yoterr's Avatar
tires, there prolly chopped really bad from the mis alignment try rotating your tires, and you should prolly get an alignment too
Old Aug 19, 2009 | 07:24 PM
abecedarian's Avatar
If I had to guess, it'd be a caster problem.
Various vehicles are infamous for a "death wobble" but it's over-rated. Just a point where the suspension is in a state where it doesn't really know which way to go and you get a wobble.
Go get it aligned.
Old Aug 19, 2009 | 07:31 PM
Plumbrbob's Avatar
yup aligment time
bigjstang
Jun 2, 2025 03:56 PM
westonian18
May 1, 2020 06:38 AM
Sep 4, 2015 09:27 AM
good-ol-boy
Jul 31, 2015 05:53 PM
ShakinIt2x
Jul 21, 2015 06:20 PM
