Towing Capacity Question..
Old Aug 19, 2009 | 02:13 PM
sonicdrft's Avatar
Hey im a new 4 runner owner and am pleased with it...I have a 95 auto,V6,2wd with around 15x,xxx..My question is i have a 93 wrangler i take offroading and i was wondering if the 4 runner will be able to tow it..And if so in what way would i be able to tow it?Just curious about it because i would not want to mess my 4 runner up..All is appreciated..
Thanks
Old Aug 19, 2009 | 02:25 PM
Tubbyfatty's Avatar
I wouldnt tow anything with the v6, and you have an auto behind it so its not a good combo.
You be hard on that v6 and pop goes the head gasket.
Old Aug 19, 2009 | 02:38 PM
Tofer's Avatar
Sponsor
i dont know about that... I've towed with my old 3.0 several times and it never had an issue.. I towed my blue truck fully loaded moving back from college from Stockton CA to Portland OR without any issues.... granted i was only able to go 35 mph in 3rd gear at 4k over the pass but it did ti like a champ.
as far as towing a wrangler, i would flat tow it if its possible. less weight with out a trailer, but you dont have trailer brakes helping...
Old Aug 19, 2009 | 02:59 PM
sonicdrft's Avatar
ok so good decision would be to find something else...i dont really want to take a chance on breaking anything...so what would u suggest as a decent tow rig...something that doesnt cost alot to buy used for like a grand or something...budget fun for now...
thanks
Old Aug 20, 2009 | 01:54 AM
TNRabbit's Avatar
1978 Ford F100 w/the 300 cubic inch 6 cylinder...
Old Aug 20, 2009 | 07:19 AM
sb5walker's Avatar
I've read many posts where towing caused the veezy gasket to blow, so I would be wary. The only way I would even consider it is if I installed headers, to get rid of the stupid stock crossover and protect cyl 6, AND, if I installed an extra trans cooler like turborich covered in this excellent writeup:
http://www.toyotanation.com/forum/sh...d.php?t=284485
Even with those mods, I think it would still be risky.
Old Aug 20, 2009 | 10:06 AM
g_cali's Avatar
Get rid of the jeep an you got nothin to worry about
Old Aug 20, 2009 | 10:25 AM
algranger's Avatar
Originally Posted by Tofer
i dont know about that... I've towed with my old 3.0 several times and it never had an issue.. I towed my blue truck fully loaded moving back from college from Stockton CA to Portland OR without any issues.... granted i was only able to go 35 miles per hour in 3rd gear at 4k over the pass but it did ti like a champ.
Yeah flat tow would be good BUT then you have dead weight pushing you with no added braking power. At least with a trailer you have the tongue weight to help your braking traction and you have trailer brakes.
I would be more worried about stopping than getting going.
Old Aug 20, 2009 | 10:44 AM
turborich's Avatar
Thanks for the props sb5walker.
I've got the 3VZE, I don't tow a vehicle with it but I have towed several things around town with my 5x8 trailer. I have hauled several loads of top soil that weighed around 2500-3000 lbs each. I also hauled my spa to my house. Now I NEVER stress the engine while towing anything. I am as light on the gas as I can be, I keep the overdrive off while towing & use the ETC switch for a few extra RPM's between shifts. I would be worried about hauling a heavy load up a hill though as things may warm up. Using headers to remove the x-over pipe is a very good suggestion if it's within your budget. It may be cheaper in the long run to pick up an old full size p/u with a V-8 then it would be to install headers & new head gaskets if things go wrong. I think the Toyota is rated at 3,500 lbs though. Just my 2 cents.
justdifferentials
14
Jun 11, 2017 08:36 PM
Brodetski
Sep 30, 2015 11:50 PM
Cycles
Sep 29, 2015 06:37 AM
Odin
Sep 26, 2015 06:56 PM
toyhaulert100
Sep 24, 2015 07:55 PM
