22re help, hard to start, runs great once started, codes 8 and 27
Old Aug 15, 2009 | 07:24 PM
neilan's Avatar
Well I have a 1987 4runner with a 22re. Engine was rebuilt 5k ago with new head etc. About 6 months ago I had to phurchase a new afm and adjust the tps. Just today it started to be extremly difficult to start. If i really work on it wihte the gas all the way down and can get it to start eventually and if i rev it up for a second before letting off it runs and idles just fine. I have been gettign an average of 18mpg with no drop lately. Plugs look good cap and rotor also arer good. When i just the ports under the hood im getting a code 8and 27. Any help would be apreciated.
Code 8:
8 or 24
INTAKE AIR TEMPERATURE SENSOR SIGNAL
OPEN OR SHORT IN INTAKE AIR TEMP. SIGNAL
INTAKE AIR TEMPERATURE CIRCUIT
Code 27:
27
SUB-OXYGEN SENSOR CIRCUIT OR SUB-OXYGEN SENSOR HEATER CIRCUIT
SUB OXYGEN SENSOR/HEATER/CIRCUIT
ECU
Old Aug 15, 2009 | 07:44 PM
neilan's Avatar
After sitting and cooling off for awhile it starts easier but still not like it should when running at idle it seems to miss a little.
Old Sep 19, 2009 | 04:38 PM
yzrider273's Avatar
just a suggestion
try unsrewing the gas cap and put it back on. it might be vapor lock
i had the EXACT same symptoms as you and i did that and it started normally
i have an 86 4runner btw
Team420
Jan 12, 2021 04:57 PM
Ichneumon
Sep 27, 2015 04:21 PM
serenity03k64
Jun 27, 2015 07:59 AM
Badger62811
Jun 26, 2015 09:26 PM
Yoda
7
Jun 22, 2002 07:14 AM
