Idle problems
Old Aug 22, 2009 | 04:10 PM
CChudalla's Avatar
Idle problems
I just bought a 1990 4runner with 30,000 on a rebuilt 22re and i am haveing a problem with the idle when i first start it it will idle low sometime it will run for about 30 seconds and then die when i restart it and rev it up to keep it going it will stay running but still idleing low after i drive it it will sometimes idle at around 1000 when i come to a stop other time it will idle around 1400 i have checked the vacuum lines they all seem good i am a mechanic in the army but this is my first toyota and i am not familer with it at all any ideas would help thanks
Old Aug 22, 2009 | 05:07 PM
metal09's Avatar
i had the same prob i just adjusted the idle screw on the throttle body and blame it work do know if its a help or not my 22re had 236000 km on it they are a strong engine
Old Aug 22, 2009 | 05:13 PM
myyota's Avatar
Try removing the throttle body and see if it needs to be cleaned, they can get dirty and the vacuum ports on them can get plugged, and that can cause an eratic idle.
Old Aug 22, 2009 | 05:20 PM
SleevelessSteve's Avatar
I agree with myyota. I drove a 95 camry before i bought my 4runner with a 2.2L engine. its got 190k on it, and occasionally has the same idle problem. what i really needed to do was clean the throttle body, but i would just pull back the air hose and squirt some carb medic down on the ports and it would start right up and idle fine. generally if you have this starting problem a little bit of revving helps, then you can go ahead and shift it into drive and you'll be fine for your trip if you can at least get going. good luck, i hope i made this easy to understand.
Old Aug 23, 2009 | 07:18 PM
CChudalla's Avatar
i have cleaned the throttle body but the problem still exists im thinking it might be the afm but im still not sure earlier today it was idleing at 2000rpm after i turned the engine off for about a hour when i restarted it it was idleing fine after a drive down the freeway at about 65 got off the freeway it was idleing at 1500rpm this has me stumped
Old Aug 23, 2009 | 07:24 PM
have you tried the tweak that metal09 suggested? maybe the previous owner set the idle high. has it had this problem since you purchased it, or is this a recent complication?
Old Aug 27, 2009 | 07:17 AM
CChudalla's Avatar
I have done that the idle screw is turned all the way down it still is doing the same thing but i think i have narrowed it down to the idle control valve any thoughts
Old Aug 27, 2009 | 08:38 AM
Junkers88's Avatar
Punctuation.
As far as the idle air control valve (IACV) goes I do know that they can cause an eratic or high idle. I have a similar issue on my 89 and am just saving money so I can purchase a new valve. I did read somewhere that you can remove it, clean it and readjust it but I haven't been able to find the information again. If I find it I'll post it up here so you can use it as well.
Welcome to YT.
Old Sep 1, 2009 | 06:36 PM
CChudalla's Avatar
I think i found out the problem i removed the throttle body in the process i had to remove the coolent line to the IACV and the inlet was compleatly clogged with crap so hopfully when i get it back together tommorrow every thing will run perfect
Old Sep 2, 2009 | 12:15 AM
ohyeahcrx's Avatar
Well let us know. Dont let this thread die without a definate answer!
Old Sep 2, 2009 | 05:41 PM
CChudalla's Avatar
yes that was it, it is now idleing at a steady 750rpm from my best guess was that the previous owners had a new engine put in but the shop that did the work didn't do a very good job cleaning the TB or the intake and the TB was sticking a little and also the guy I bought it from said he used some of the radiator fix crap and that along with a little rust clogged the IACV inlet now i can't say every idle problem is caused by this but it could be the fix for a lot of people because for me it did not throw a CEL
Old Oct 2, 2011 | 08:01 PM
1990slowrunner's Avatar
hey guys. im a new user but not a new yota owner. i have a problem that im hoping someone can help me with.
i have a 1990 4runner with the 3.0 v6. the engine was filthy so i decided to take it to a self serve carwash and washed off the engine. it started and ran fine on the way home. i parked it for about and hour and when i came back to go to the store it wouldnt start. starter was turning over fine but it just wouldnt kick over. i pulled off the distributor cap and dried out the little amount of water that was in there. it would now start but runs like crap and then dies. any ideas on what i messed up or what i can do to fix this problem? thanks in advance.
Old Dec 6, 2011 | 09:24 PM
mhoupt856's Avatar
I have a similar issue with my 95 4runner V6 4WD. When I start up the engine it cold idles at ~800. After driving the vehicle (anywhere from 15-30 minutes) when I put it in park the rpms go to ~1800.
I am just looking for a place to start looking to diagnose the problem. Also, recently the overdrive light flashes after driving for fifteen to twenty minutes.
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
Jnkml
Jul 6, 2015 01:20 PM
