1993 truck door jamb sticker information needed
Old Aug 14, 2009 | 04:46 AM
PhilR's Avatar
1989-95 SR5 V6 truck door jamb sticker information needed
Hi,
Can someone with a 1989-95 Xtracab SR5 truck equipped with the manual transmission, 31" tires and 4.56 axle ratio show me the information on their door jamb sticker?
This one is from my 4cyl 1990 but I need information from a SR5 V6 manual with 31X10.5 tires.
Old Aug 14, 2009 | 05:33 AM
mojoman's Avatar
http://www.brian894x4.com/Gearratiosanddiffs.html go here
Old Aug 14, 2009 | 08:21 PM
PhilR's Avatar
Thanks for the link, but I need the information on a SR5 V6 truck with 31X10.5 tires (I need information like GVWR and GAWR front and rear, tire pressure and other codes to have the door jamb sticker correctly reproduced by Toyota... )
My sticker is gone since this part of the body was replaced after an accident. Toyota Canada sent me a document that I need to fill in so I could get a reproduction sticker...
So if anyone could sent me a picture of their door jamb sticker, that would help me!
Old Aug 14, 2009 | 08:44 PM
abecedarian's Avatar
Should be able to get the sticker based on the VIN since the VIN should reflect any options installed on the vehicle.
Old Aug 14, 2009 | 08:55 PM
PhilR's Avatar
I already had some VIN information but some (such as the tire pressure and tire size, GVWR an d GAWR) isn't shown... I got the trim code, the color code and most other information needed.
Here's the information I already got with the VIN:
VIN information
Division: TOYOTA Model: Truck Grade: SR5 Model Year: 1993
Drive Type: 4WD Body Type: Extra Cab Engine Family: V6 - 3VZ
Date of First Use: 10/13/1993
Line Off Date: 07/04/1993
Plant Code: N - TMC PLANT - JAPAN
Standard Equipment:
3.0 LITER V6 OHC EFI ENGINE
5-SPEED MANUAL OVERDRIVE TRANS
2-SPEED MANUAL TRANSFER CASE
4WDEMAND / POWER STEERING
POWER VENTED FRONT DISC BRAKES
HI-TRAC INDEPENDENT FRONT SUSP
REAR ANTI-LOCK BRAKES / GAS
SHOCK ABSORBERS/STYLED WHEELS
P225/75R15 RADIAL TIRES (5)
60/40 CLOTH SPLIT BENCH SEAT
REAR CLOTH JUMP SEATS
FULL CARPETING / TINTED GLASS
ETR RADIO W/2 SPEAKERS
TILT WHEEL/VARIABLE INT WIPERS
Exterior Color: 0196, PEWTER PEARL Interior Color: GA11, GRAY CLOTH
Interior Trim Color: GA, * Interior Fabric: F, *
Accessories:
AC : AIR CONDITIONER
AW : ALUMINUM WHEELS (4) W/31"10.5
CH : CHROME PACKAGE INCL: CHROME
CK : ALL WEATHER GUARD PACKAGE
CL : CRUISE CONTROL
CT : CARPETED FLOOR MATS 2 PC SET
EX : DELUXE ETR/CASSETTE W/4 SPKRS
FS : 40:60 FABRIC SR5 W/SSA
PA : FLEET DISCOUNT
PO : POWER PACKAGE INCL: POWER
SC : PREMIUM CHROME STEP BUMPER
SR : SUNROOF
SX : SPORT PKG INCL: GRAY PRIVACY
VP : VALUE PKG INCL: CHROME PKG,
WR : REAR SLIDING WINDOW
Campaign Description: 50N - CERTAIN 1989 - 1995 TRUCK 4WD, 1990 - 1995 4RUNNER 2WD AND 4WD, AND 1993 - 1998 T100 (4WD VEHICLES EQUIPPED WITH POWER STEERING) STEERING RELAY ROD REPLACEMENT
Completion Status: Completed
Date Serviced: 07/18/06
Dealer Name: BRISTOL TOYOTA, INC.
Dealer Code: 38019
Campaign Description: V06 - 3VZ-FE V6 Engine Head Gasket
Date Serviced: 08/27/98
Dealer Code: 38019
Old Aug 14, 2009 | 09:11 PM
oddly, the VIN information you have states the truck came with
not the 31" option...
but then says:
It would seem Toyota Canada already has all the information they need to reproduce the sticker based on the VIN.
Old Aug 14, 2009 | 09:16 PM
PhilR's Avatar
Actually, it's more complicated than that. My truck was sold in the US and Toyota Canada doesn't have any information about it.
The list I sent shows standard equipment of the SR5 trucks and the options on mine below. The 225 tires are standard but on my truck, the tires are 31X10.5 R15 (see the options). Also note the two speaker radio in the standard equipment list. Mine had 4 speakers and used to have a casette player. The standard seats were 60/40 but mine has the bucket seat/console option...
Old Aug 14, 2009 | 09:20 PM
Yeah. In my reply I noted the option for the 31x10.5" tires on Aluminum wheels.
Maybe you should contact a Toyota USA dealer?
Old Aug 14, 2009 | 09:33 PM
PhilR's Avatar
I did, that's where I got the information above! But I got some information which seems wrong!
(tire inflation pressure 26 front and 29 rear) and GVWR 5350 GAWR front 2285 and GAWR rear 1520...
And I don't know exactly how iss written the tire dimentions on the sticker, On the document I have, I need to fill correctly the cases and I don't know how to enter the tire size.
Weidle
Jan 21, 2019 05:39 AM
Colington
Oct 12, 2015 05:41 PM
David_Vestfal
Jun 20, 2002 08:30 PM
HALMAN
Jun 14, 2002 09:02 PM
