electrical issues
Old Aug 22, 2009 | 05:41 PM
schnittzle's Avatar
electrical issues
hey guys im new here and its a nice site u got here. i got a 86 4runner and my starter locked up wich caused my ground and main positive to burn up so i replaced all that and she still wont start so how do i test wat else burned up or find out why it wont start ?
Old Aug 22, 2009 | 06:01 PM
BigBluePile's Avatar
Welcome to Yotatech!!
Hmmm, might want to check the fuse box there by the battery. There's a couple high amp fuses there that might be bad now.
Old Aug 22, 2009 | 06:20 PM
myyota's Avatar
Check the main 80 amp fuse in the fuse box by the battery, there is also an ignition fuse inside the truck behind the driver side kick panel. either one of those could keep your 4Runner from starting.
Old Aug 22, 2009 | 06:34 PM
iamsuperbleeder's Avatar
isn't the power to the starter direct, as in no fuse?
is there any clicking at all from the starter when you turn the key?
if so, then at least it's getting power
if not, then you're looking at the ignition circut
Old Aug 22, 2009 | 06:40 PM
myyota's Avatar
Thats true, i wasn`t thinking about that, but there is an ignition fuse behind the driverside kick panel.
Old Aug 23, 2009 | 12:53 PM
wyoming9's Avatar
Red face
You still need the power from the ignition switch to energize the coil in the starter solenoid to pull in the contacts so the battery power can then turn the starter .
This is one of those that you need the electrical manual and good multi meter.
Does it crank but not start or no crank??
If it cranks look to see if you have spark and fuel .
It could be one or more of the fusible links has melted you could have melted some of the wires on the positive battery terminal .
Check all your fuses and fusible links as a start.
coryc85
Sep 9, 2015 06:24 AM
jjrbus
Jul 27, 2015 11:06 PM
v_man
Jul 23, 2015 04:01 PM
Poncho0206
Jul 10, 2015 06:21 PM
AaronM
Jul 8, 2015 07:15 PM
