drive line blues
Old Aug 22, 2009 | 11:08 AM
jojapro's Avatar
drive line blues
quick question. should i be able to rotate my drive shaft at all with the e brake on and the truck in gear?
Old Aug 22, 2009 | 11:22 AM
swapped89's Avatar
definatly not. if u can then you skinned your ring and pinion and broke the tranny or the tranny is not in gear and you skinned the ring and pinion.
think about it for a sec. the driveline turns the tires. if the tires cant move the DL cant move.
it might move slightly but no full turns or quarter of a turn or anything like that
Old Aug 22, 2009 | 11:24 AM
jojapro's Avatar
yeah yeah, Im not talkin full rotation, just a little play
Old Aug 22, 2009 | 11:26 AM
swapped89's Avatar
mine dont move at all
Old Aug 22, 2009 | 11:34 AM
jojapro's Avatar
mine moves about 3/16 of an inch. What could this mean?
Old Aug 22, 2009 | 01:22 PM
swapped89's Avatar
its probably fine. i wouldn worry about it unless its vibrating or makin bad noises goin down the road
Old Aug 22, 2009 | 01:31 PM
myyota's Avatar
Check the u-joints, when they wear out you can get a little play in the drive line.
smthwsn357
May 1, 2024 07:28 AM
Sep 4, 2015 09:27 AM
87turboPA
Jul 12, 2015 07:49 AM
TokyoD23
Jul 12, 2015 06:01 AM
87turboPA
Jul 9, 2015 05:58 AM
