new clutch fail
Old May 2, 2018 | 05:31 PM
Robert Mason's Avatar
new clutch fail
I tried to install a new clutch kit and ended up having a grinding each time i pressed the pedal and would not shift while engine was running.
i have double checked i put the clutch plate on correctly and, I didn't install the throw out backwards used a new clip i am at a looking for any suggestions as to what may have lead to this
brand new t-o bearing guide eaten
all 4 clips where bent
new pressure plate looks like uneven pressure or wobble
all 4 retainers are bent out so bearing fell apart
clutch fork looks good to me
Old May 2, 2018 | 11:46 PM
wyoming9's Avatar
Red face
Before you started the install did you compare the parts that came out with the new kit ??
Anymore things are packaged wrong .
Then it might have been a bad clutch release bearing .
Did you torque the clutch plate in the proper fashion ??
Just which clutch kit did you go with ??
Old May 3, 2018 | 09:56 AM
from truck no this is not how mine was installed pic from google
from kit
so yes they are different so were the pressure plates i assumed due to a change in bearing, the fingers on the new plate don't go out as far,
clutch plate was torqued following included instructions
Torqued flywheel down according to chiltion
Old May 3, 2018 | 11:29 AM
Kolton5543's Avatar
It looks like you may have had the wrong bearing. What brand kit did you use? Most of the part store kits I won't use the bearings in. I've redone many clutches over a failed bearing. I usually will buy a National or Timken bearing the same time I buy the kit. I've never had a problem with either of them. The only part store kit I trust the bearings are Napa. They use Napa branded LUK kits. LUK is good stuff. They're an OEM for many car companies. I usually will spend the extra time and money to get a LUK kit online.
Old May 3, 2018 | 12:05 PM
i used one from rockauto figured while i had the block out i would change the clutch. Made my first mistake ordering part before i had the car apart. this kit to be specific FENCO/FENWICK NU31197 (Daily Driver) Reman
Fits9-1/4" DISC - TEETH 21 - STD KIT - SPLINE 1-1/8
OrNew Clutch Kit; 9-1/4" DISC - TEETH 21 - STANDARD KIT - SPLINE 1-1/8
Old May 3, 2018 | 03:04 PM
OCS12's Avatar
Before you beat yourself up over any screw ups, I’ll say that I just went through the same thing. With a brand new transmission and clutch, my truck wouldn’t shift gears. After a little back and forth, they took the clutch back under warranty. It’s replacement is smooth as silk. If I had to guess, I’d think there is a small amount of manufacturers cranking out clutch kits for old trucks. Could’ve been a bad batch.
Old May 3, 2018 | 05:31 PM
Going to put old on back in till it fails hopefully no damage was done. Nothing was wrong with it just figured I would replace while engine was out.
90veezee3
Mar 18, 2011 06:46 PM
SleevelessSteve
46
Jan 24, 2010 10:32 AM
path
Jul 9, 2008 11:04 PM
jungle_runner
Jun 5, 2007 10:00 PM
