Transmission options for 22rte
Recently bought a 86 pick up 4x4 on 1 tons with a w56 transmission which already broke. I cant seem to find a w56 anywhere to replace it so I was wondering is there any transmissions that will bolt on? If so, which cars/trucks canr with it. Just joined today brw
A quick search will give you results you are asking. But there are many that will bolt right in from a g54 to a R151f. The shift locations will be slightly different depending on whether the one you get is a forward shift or not. The r151f that was stock with the turbo truck is highly sought after and stronger than the other options, But hard to find compared to the w56. Your next best bet in regards to strength is the w56 then the g54. You can also put in a r150 if you have a turbo bellhousing and a gear drive tcase adapter. But getting the bellhousing from the r151f to use the r150 alone will make it difficult to get what you need.
Yotafunk
Jan 10, 2012 03:33 PM
JWillyG
Dec 8, 2010 06:19 PM
83Chero
Apr 21, 2009 09:54 AM
swerks
Nov 9, 2006 09:24 AM
