22re overheats while driving cools on idle
Old May 23, 2018 | 06:06 AM
ChrisR333's Avatar
89 pickup. 22re. Replaced water pump 3years ago. ( it massively failed the impeller fell off and the fan was spinning off axis). I have been having issues with it running hot since last summer. Both times I just took out the thermostat. I am currently running with no thermostat. Last summer it would run hot when I coasted down the canyon. It would cool off when I put it in gear and ran the engine at higher rpm’s. This year exact opposite is happening. I put it in gear and start driving it heats up and when I press the clutch and take it out of gear it immediately cools down. Any suggestions would be appreciated. This is my daily driver. Thanks
Old May 23, 2018 | 08:14 PM
RAD4Runner's Avatar
Maybe liquid coupling aka fan clutch is bad?
Comparing Good and Bad Liquid Coupling would not cost you a penny:
https://www.yotatech.com/forums/f199...l#post52229129
Old May 23, 2018 | 09:10 PM
NYHumpinUtah's Avatar
Also, check your top radiator hose. My friend had the same problem only to find out that at higher RPMs the top hose was collapsing shutting off the coolant flow.
Old May 25, 2018 | 06:58 AM
L5wolvesf's Avatar
Just a thought. With all the on and off of parts - did the system get completely burped each time?
That_Rad_Wagon
Apr 27, 2018 09:08 AM
ToyoTuba21
Mar 19, 2018 06:48 AM
Hilux1994
Mar 11, 2018 04:45 PM
nate2002
13
Apr 13, 2004 05:16 PM
