Brake line problems
Old May 20, 2018 | 07:53 PM
86overland's Avatar
Brake line problems
i removed my lspv on my 86 pickup and now I can’t get any solid pressure of brake fluid to through any of the bleed valves on fronts or rears. I’m stuck and i have absolutely so idea of what it can be. Also the master cylinder is brand new
Old May 20, 2018 | 08:01 PM
Yotard's Avatar
The front and rear brakes are completely isolated systems that's why there are two different lines coming off of the master cylinder so deleting lspv isn't going to cause it. Sounds like you didn't bench bleed the new master cylinder.
Old May 20, 2018 | 08:43 PM
86overland's Avatar
I bench bled the master cylinder and when I try to bleed the lines is when I have no fluid getting to them.
Old May 20, 2018 | 09:42 PM
thefishguy77's Avatar
I'm fighting rear brakes right now and it making sure your drums are adjusted. And getting all air out of the line. Once the bubbles have stopped flowing from that one go to the drivers rear and repeat. If you didn't touch the fronts don't worry about it as long as you never let the MC go dry. If so the do the same for the fronts. Then properly bleed them and you should be good.
Bleeding order.
LR
RR
RF
LF
LSPV
Old May 20, 2018 | 09:44 PM
NYHumpinUtah's Avatar
Could be a bad master cylinder, did you try removing one of the lines near the MC and push the pedal to see if fluid comes out?
Old May 20, 2018 | 11:06 PM
wyoming9's Avatar
Red face
What did you do with the lines from the LSPV ??
It can be one of two things
Bad rebuild
kinked or dirt in the brake lines
Enough mud in the bleeder valves fluid can`t push through . that should be easy to see
Old May 21, 2018 | 04:14 PM
86overland's Avatar
The mc is brand new but I can check to see if it will push fluid and the lines to the lspv are new but I removed the lspv and plugged the return line.
Old May 21, 2018 | 05:07 PM
muddpigg's Avatar
what did you do at the T junction behind the front passenger tire? The front and rear circuit on the 4wd ARE connected. Any poodles of brake fluid on ground under the truck?
Old May 21, 2018 | 05:23 PM
akwheeler's Avatar
Like mudpigg said, look for puddles and Wyoming mentioned plugged bleeders, I've seen it often. Pull one all the way out and make sure it is clear, I clean them out with a small drill bit then blow them out and put them back. if that works for one corner work your way around as you bleed.
Old May 21, 2018 | 06:07 PM
86overland's Avatar
I plugged it with a bolt and no puddles. It’s not just the bleeders that have no pressure I’ve popped random lines and it’s still hardly pushing fluid out.
Old May 22, 2018 | 05:12 AM
akwheeler's Avatar
If you bench bled it then you got fluid to move, so don't be random about breaking lines apart checking for fluid. systematically move farther and farther from the master cylinder until you stop getting fluid. then look for the blockage just upstream.
If you got fluid to move when you bench bled the master cylinder and you don't have any leaks either your pedal isn't moving the master cylinder or you have a blockage in both lines, or you are doing something wrong. try filling the master cylinder, leave the cap off, open all your bleeders and wait. see if the level goes down in the master cylinder.
Deathvalleypaul
May 13, 2015 05:51 AM
kevinwantwant
Feb 5, 2015 05:05 PM
nobb
Jan 9, 2013 05:23 PM
headhunterlum
Sep 13, 2008 06:59 AM
WatsonMD
Dec 23, 2003 07:17 PM
