Oil in coolant fresh engine!!!!!
Old May 18, 2018 | 08:18 AM
treed410's Avatar
Unhappy Oil in coolant fresh engine!!!!!
Hey guys!!! I put a refurb 22RE in my '95 pickup 4x4, ran it through the engine shops recommended break in procedure, put 500 miles on the engine, and now have oil in my coolant BUT NO coolant in my oil. I got in touch with the mechanic from the shop I bought the engine from and explained the situation to him (thinking possible blown head gasket) and he said its extremely rare for a fresh head gasket on fresh milled surface with fresh head bolts to go bad. He also said that from his experience it sounds more like a timing cover flaw. I'm just trying to find out how to test a timing cover and I am seeking advice on anything else it could be. I have a run for memorial day weekend I am trying to make. Please help!!!
Thank you everyone in advance!!!!
Old May 18, 2018 | 08:40 PM
NYHumpinUtah's Avatar
Of course that's what he said, otherwise it would be his problem. What you need to do is do a compression test and see if you can tell if the HG is blown. Make sure you remove all the spark plugs when you do the test. If you don't know how just google it, How to check for a blown HG
Good luck
Old May 18, 2018 | 09:02 PM
akwheeler's Avatar
did you replace the engine due to the old one failing? any chance the oil was trapped in your radiator and heater core since then?
How much oil?
Old May 25, 2018 | 06:27 AM
treed410's Avatar
Yeah I swapped the engine do to a split cylinder wall now that I think of it I don't remember cleaning out my heater core or radiator. Thanks for the help bud! I will clean them and get back with you guys!
Old May 25, 2018 | 08:21 AM
akwheeler's Avatar
Yup, don't panic until you verify that you are loosing coolant or oil. If you clean out the cooling system and everything is staying full you don't have a problem.
Old May 25, 2018 | 10:41 AM
jakey poo's Avatar
I'd also verify the head was torqued to the new specifications.
redwolf3
Aug 4, 2011 05:45 PM
AZprospecter
Apr 5, 2011 07:47 PM
Z's Confederate Toy
Feb 21, 2011 05:11 PM
tfan
Dec 23, 2010 10:14 AM
Stumpy
Aug 5, 2007 05:25 PM
